Milwaukee Eight funny problem!!! Drunk enineers???
Old Mar 8, 2017 | 07:24 PM
  #31
13RoadKing's Avatar
13RoadKing
Originally Posted by Arseclown
Why is the initial op post deleted?!
I don't like negative responses.
Old Mar 8, 2017 | 07:26 PM
  #32
PapaThiele's Avatar
PapaThiele
He got his sand in his vag and had to delete
Old Mar 8, 2017 | 07:28 PM
  #33
13RoadKing's Avatar
13RoadKing
So is there any issue? IIRC xxyzx has an M8 with 25000 miles on it already.
It is design problem, even if it shows up at 100k miles.
We need to see rocker arm, maybe there is adjustment screw on one of 2 levers.
Old Mar 8, 2017 | 07:44 PM
  #34
Max Headflow's Avatar
Max Headflow
You design motors? So whats wrong with the design? Have you seen issues with this before?
Old Mar 8, 2017 | 07:50 PM
  #35
TwiZted Biker's Avatar
TwiZted Biker
I've seen the rocker arm, there are no adjusting screws.
Do yourself a favor , google M8 engine cutaways and actually read some of the tech specs that go along with the pictures, this isn't a Hustle mag.
Old Mar 9, 2017 | 11:14 AM
  #36
13RoadKing's Avatar
13RoadKing
I don't design motors, I was repairing car engines for 23 years.
Attached Thumbnails Milwaukee Eight funny problem!!! Drunk enineers???-m8.jpg
Old Mar 9, 2017 | 12:18 PM
  #37
Max Headflow
From the pic, you say 0.012 makes noise. Where did that number come from?
Based on the HD spec of 0.003 difference in stem protrusion, there shouldn't be an issue then?
Old Mar 9, 2017 | 01:14 PM
  #38
13RoadKing's Avatar
13RoadKing
Probably 0.015 or more will make bad noise, not .012.
Exhaust valve clearances of adjustable valves have highest .014 specs. They make minor noise.
You will not hear .003 valve clearance. Nobody can predict what will happen to M8 engine valves after 50k miles.
Old Mar 9, 2017 | 01:32 PM
  #39
Max Headflow
So what causes the rattle at 0.014? Is this reference to a motor with hydraulic lifters? Do you think that the 0.003 on one valve can grow to 0.012 thile the other stays the same? IME if a valve beats itself into the seat 0.010 more then another it's pretty much shot.
BTW, As I mention in another post, simply make the pick up and set-down ramps bigger / longer to accommodate the variance in stem lengths.
Old Mar 9, 2017 | 03:53 PM
  #40
djl's Avatar
djl
It's all the fault of those lazy HD "enineers".
