What cam to pick
Old 04-30-2017, 04:02 AM
03Roadking63's Avatar
03Roadking63
03Roadking63 is offline
1st Gear
Default What cam to pick
i had thought my motor was LOUD but everyone i asked said " thats how they are " i have 40,000mi on it and it didnt sound right.finally had it checked.outer tensioner was destroyed and inner was wearing on the pin.Narrowly escaped catastrofic engine failure.id like to up my cams,how much bigger can i go with everything else stock ??? and i can upgrade to hydrolic ??? i have a stock 2003 Road King FI
Old 04-30-2017, 04:28 AM
2013_FLHTK's Avatar
2013_FLHTK
2013_FLHTK is offline
Received 1,043 Likes on 258 Posts
Are you going to do the work yourself or have a shop do it for you?
Old 04-30-2017, 09:42 AM
03Roadking63
1st Gear
Default doing it myself
I am gonna attempt it myself, im pretty mechanicaly inclined and with videos online im pretty confident i can get the job done. also i dont have the $2,000 i was quoted to get it done lol
Old 04-30-2017, 11:48 AM
Lunchboxx's Avatar
Lunchboxx
Lunchboxx is offline
My bike is an 01 i used s&s .509 which i believe is about the max you can use with stock springs. Some prople say they have used 525 but if you go that route its recommended to check for coil bind of your valve springs. I also just put CYCO pads on the stock tensioners. Cheaper that wAy. Just have to check them once in a while. Follow your service manual and its not a hard job to do. Just pay attention to the o-rings around the oil passages when putting everything back together. I also used S&S lifters and adjustable pushrods
Old 04-30-2017, 12:11 PM
03Roadking63
1st Gear
Default Ty Lunchbox
Hey thank you very much, im thinking i will stay with the 509 or just under to be safe but would like a little more so
Old 04-30-2017, 05:06 PM
2013_FLHTK's Avatar
2013_FLHTK
Do you already have a tuner or is the bike still stock?
Old 04-30-2017, 09:13 PM
03Roadking63
1st Gear
Default all stock
no tuner straight stock
Old 05-01-2017, 04:36 AM
2013_FLHTK's Avatar
2013_FLHTK
You should call S&S and Fuelmoto to discuss a performance package that will include an updated tune and everything thing else you need. I like the S&S 509 for your motorcycle.
Fuelmoto sells these mufflers for a great price if you are trying to keep your costs down.
https://www.fuelmotousa.com/series-2...%20KING%20FLHR
Either way purchase everything from one vendor and get a map that best matches your setup.
Old 05-01-2017, 05:42 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
A set of Andrews 21 cams, will bring VERY GOOD low-mid torque into the picture, and if so inclined, later, you can step up the power to a 95-98" engine, bringing the 21's along also with the use of a 1.725 rocker arm.
.509's are also on the very short list for a plug/play 88" cam swap.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
ScottinAZ
Engine Mechanical Topics
25
02-19-2019 05:31 PM
Teagan
Shovelhead
07-17-2018 02:14 AM
05dlx
2014-2023 Touring Models
13
05-27-2015 07:25 PM
98 Heritage N.Indiana
08-15-2011 09:05 PM
screemnjay
Exhaust System Topics
07-23-2006 02:33 PM
Quick Reply: What cam to pick
