Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Did your exhaust come with 18mm ports or did you install them? Is the dyno tuner eliminating PE mode? His he trying to just roll on test or is he step testing?
I have seen good and bad w/ cobra. Their 2-1 surprisingly impressed me more that I thought. No experience with that header though.
Thanks for the response...They came with both bungs.
As far as what the tuner did. I don't think he knew too much. He didn't mention anything other than saying he couldn't get it to stop going rich on the top end without damaging something. Not sure what that meant. He wasn't able to give me a print out of the dyno, that was a picture taken with my phone. He disconnected the Target Tune and said that it would probably mess up what he did. He was really pushing another company's cams saying that's what he's used to working with (I think he wanted me to have them switch out mine).
Now I have the whole thing taken back apart, it wasn't sumping, cam timing was correct. Just not sure whether to put the 204s back in or put the stock back in, or try a different set of cams.
Reason: add
Sounds to me that you found a tuning program operator and not a tuner. If the "auto" doesn't take care of it he is lost.
PE mode might be suspect. It will cause the ECM to richen up during WOT and it can also make the ECM ignore the closed loop feed back in that area. I know and understand it is advertised as 100% closed loop but that is not how the Delphi ECM o2 feed back system works. Remember that DJ didn't do anything special for this all to work. They just tapped into the old developers code that was already there, and it was never made to do what they are trying to do with it.
Did you provide the "dyno tuner" the map that Fuel Moto sent you on a thumb drive?
Don't take for granted he has the ability or cares to read the loaded program and start his tune from that map....
If you have the ability, store his map and compare timing tables against Fuel Moto's map.
See if he started with that map. I'd compare the enrichment, etc... tables as well....
I don't think the 204 cams are the issue but the person trying to do the tune is. re-install the 204's and find you another tuner somewhere but do your homework and find a reputable tuner and you should be fine.
No, I didn't give him a copy of the original map. I spent about an hour comparing the new map to my previous Target Tune map and couldn't make heads or tails of it. He did make some timing changes, but nothing drastic. I didn't check enrichment. Everything else just started running together.
Thanks for all the input. After reading the posts and thinking about it a few days, I think I'm gonna put back in the 204's and plan a roadtrip down to Alorton, IL and see Hrdtail78. On a positive note, I have 100 ft lbs at 3000.
