Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
As other have stated 178 is a little low if checking the CR at 900 ft level (Bow NH). If running flat tops as a 110 and 85 cc stock ported heads the compression ratio should be about 10.6 to 10.8 to 1 which should net you about 200 to 210 psi at sea level.. Motor will likely not need much timing to run. You may want to find someone else to tune your bike.
When doing the compression check, are you holding the throttle wide open? Is throttle system fly by wire?
I did not hold it wide open. Oops!! It's a 2009 so yes tbw. I'll have to check it again.
If this motor is built right, my bet would be that you got way too much timing and the guy tuning only has experience with stage 1 bikes... I've run 10.8 with 42 degree close. CCP was 220 psi.. Once dialed it it rarely pinged.. Did get some when I was trying to bring up the gas mileage tho..
