2004 electra glide build question mostly cam related
Old May 24, 2017 | 04:05 PM
wizzbane's Avatar
wizzbane
Stage III
Default 2004 electra glide build question mostly cam related
For starters I have a 2004 electra glide with 47k miles.
Looking to give here and upgrade.
The plan so far the plan is up the 88 to 95ish cI
A changed cam, upgrade to hydraulic cam tensioners.
So far have some parts from a ex buddy that like to keep his bike a work in progress. Have 2 different andrews cams the 26n and the 48n,both with less then 2 k on them and stock heads off a 2007 electra glide.
I plan on having head work done and then buy big bore cylinders/pistons not sure what compressoo which brings me to the main question.
Since I have 2 sets of cams and I am cheap ,I have the rpm range and the compression likes for the 26n but can't info on the 48n in regards to it rpm range and compression it likes.
Right now ride mostly 2 up with the bike running heavy .
Since I am gonna run either of these 2 since free which would be a better choice since using the newer heads.
Tia
Wizzbane
Old May 25, 2017 | 05:42 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Either of those cams will work well.
I'd bore to 98", and just a Stage I Head.
Scott
Old May 25, 2017 | 08:15 AM
nhrider1's Avatar
nhrider1
Tia
Wizzbane
I have the 48n's in my 88 with hydraulic conversion. They are good cams with a strong low/mid range. Works good with my stock compression, would probably work better with a slight boost and headwork.
They are really strong in my 96. 96 has slightly higher compression (9.2 vs. 9.0) and better heads.
Old May 25, 2017 | 10:13 AM
dfwhockey17's Avatar
dfwhockey17
We just put the 48's in a customers 96" with no headwork, an HPI air cleaner and cobra 2-1 exhaust. It dynoed at 81hp and 101tq with our direct link tune. The power comes on early and stays late. With headwork and a slight compression bump they will work great for you, especially since you ride two-up like you mentioned...I'll post the sheet when I find it.
Old May 26, 2017 | 10:13 AM
wizzbane's Avatar
wizzbane
Stage III
Originally Posted by dvr
The 48 cams are pretty nice upgrade over stock, but with the correct head work they can be pretty awesome. check out this dyno sheet;
http://www.harleytechtalk.com/index.php?topic=90486.0
if i read the dyno sheet right the 48 seems to come on at about 2100-2200 rpm?
awente@comcast.net
Exhaust System Topics
Oct 14, 2012 04:44 PM
jrgreene1968
Sep 5, 2012 02:59 PM
AZRenegade
Mar 17, 2012 09:53 PM
brokeboystreetglide
21
Oct 16, 2011 12:20 PM
lawndart899
Engine Mechanical Topics
Jan 17, 2011 05:40 PM
