backfire
Old May 29, 2017 | 10:00 AM
wichris's Avatar
wichris
6th Gear
It was 180 off. Have to switch the wires and plug wires so they are not so crossed up. Definitely something with the exhaust valve/spring. Not looking forward to pulling it all apart again.
Old May 29, 2017 | 10:21 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Sorry missed the 82 Shovel info... Still though there's got to a way to remove springs without pulling the head...... I'm new to shovels so i haven't tried anything like that yet on them....... Picked one up last December and haven't really messed with it yet........ Most of my time was going into my Evo..... I'm sure some one will pop up with an idea....... or a tool........
Old May 29, 2017 | 10:45 AM
wichris's Avatar
wichris
6th Gear
Might have enough room to pull the head without removing the motor. If I could get the rocker box off I could do the spring without taking the head off. Maybe next weekend.
Old May 29, 2017 | 11:08 AM
Max Headflow's Avatar
Max Headflow
I was thinking you should... Head only needs to come up about 1/8 inch.. I've not pulled a shovel or earlier head in 40 years.
Old May 29, 2017 | 01:37 PM
wichris's Avatar
wichris
6th Gear
40 years ago I did this for a living. This motor would have been brand new when I sold out the shops. This is supposed to be relaxing doing it for yourself. Too close now to just put it off.
Old May 29, 2017 | 04:16 PM
wichris's Avatar
wichris
6th Gear
Found the problem. Bought new rocker covers(drag specialties)and the casting is bad. Valve retainer hits the casting. A little grinding and a new retainer and it will be good to go. Going to pull the front off to make sure nothing hits there.
Old May 29, 2017 | 06:33 PM
Max Headflow
Looks like someone installed / removed the left rocker cover stud with a pair of vise grips..
Old May 29, 2017 | 07:03 PM
wichris's Avatar
wichris
6th Gear
I imagine in the 30 years before I had the motor there has been a lot of that.
Old May 29, 2017 | 07:53 PM
Max Headflow
Yeah,, You can tell the guy that owned it before you was a hack.. Gasket surface was chiseled at. I gave up on trying to find an oldie to restore.. Better to use new cloned parts.. Less chance of someone messing them up, tho they can have their own issues like your valve collar clearance issue.. I've made that mistake putting together an old round cylinder B44..
Old May 29, 2017 | 08:45 PM
98hotrodfatboy
Good find. A little die grinder work and you're good to go.... would love to hear a sound bite once you get it all straightened out... good luck man....
