Baisley Pro street Heads
Old Jun 26, 2017 | 11:48 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Not trying to stall your thread . Sorry......
Also I wasn't trying to knock anyone here... What I do know is that Baisley's heads are top notch and I'm not putting them down at all.......
I'm not a engineer and understanding flow studies can be misleading. What I do know though is the my Evo heads are flowing 161 CFM front cylinder head and 162.5 CFM rear cylinder head at 10"@.600 lift. Most likely more than enough for the street...
If you want want Baisley's heads for the street go for it. But you are gonna pay just make sure all the other components match the heads.....
Old Jun 26, 2017 | 11:54 AM
Bap227's Avatar
Bap227
I'm not a machinest and understanding flow studies can be misleading. What I do know though is the my Evo heads are flowing 161 CFM front cylinder head and 162.5 CFM rear cylinder head at 10"@.600 lift. Most likely more than enough for the street...
So his heads are more for racing you saying?
Old Jun 26, 2017 | 12:11 PM
Max Headflow's Avatar
Max Headflow
Those numbers make more sense.. The low 160s flow is plenty for the street as long as the motor ain't too big but it really depends on where you want the power, target CR etc.
Old Jun 26, 2017 | 12:21 PM
Bap227's Avatar
Bap227
Looking for mid to top end
Old Jun 26, 2017 | 12:42 PM
Max Headflow
Baisley heads on a 117? Absolutely.. Like Paul Morris says, with Baisley stuff you are paying a little more but it's worth it.. Your motor will blow the 124 crate motors in the weeds and vibrate less in the process.
Old Jun 26, 2017 | 01:49 PM
98hotrodfatboy
His head's will definitely get you top end without a doubt. Provide you have all the other proper (matching) components... Me I like low-to-mid and yes I like top end as well but all the real power is mid-range, low-end to mid-range for the street..
A couple of weeks ago I had my bike on the Dyno doing fifth gear runs (I have a 6 speed transmission) in 5th gear on the Dyno I was doing about a 135 miles an hour at 6200. 6th gear @ 6200 would be way up there. Honestly i'll probably never see that on the street. There's a lot to chassis set up when you doing those speeds. Not to mention the proper tires.... An H rated tire ain't gonna do it...
Every one is different. We all have our desires and if that is what you want then by all means go for it... Never second guess yourself and don't skimp. Do it right the first time...
And Yea, Paul Morris.......... That guy is in another zip code..... He knows power......
Old Jun 26, 2017 | 02:38 PM
Bap227's Avatar
Bap227
S&S 117 cylinder and pistons
S&s lifters and push rods
Easy Start 585 cam
HPI 58 With injectors
Boarzilla
Bandit clutch
Baisley heads.. Maybe lol
Old Jun 26, 2017 | 02:41 PM
Bap227's Avatar
Bap227
That's my goal it took 10 years to do it and I don't wanna touch it again. I just wanna make sure I'm headed in the right different before I start.
Because 2200 is not easy money
Old Jun 26, 2017 | 04:05 PM
cdonis's Avatar
cdonis
I see you are in my area. You ever go toward the foothills?
Old Jun 26, 2017 | 07:38 PM
Bap227's Avatar
Bap227
Nope never been there
