T-Man 590 or 625
Old Jul 5, 2017 | 01:18 AM
rhuff's Avatar
rhuff
Default T-Man 590 or 625
Doing a cam swap from Andrews 67 in an all-bore 107. Getting CCP double checked when bike goes in-but I had it checked recently and it came back lower (180) than what it should have been (~200).
Current set up is 10.5-1 static, R&R stage 4 heads, 50mm SE TB, Kury Powercell header with Khrome Werks 3.5" mufflers. I don't like how soft the cam is on the bottom. Granted, the CCP is likely too low as well, but pretty sure I'm going with another cam regardless. The tuner is not a fan of the 67 cam either.
So, figuring all is sorted out with the CCP, what cam and why? I've been told either will be a fine choice. This is in a 03 RK that is ridden 70/30 solo and is no longer a cross country tourer, but I do like to get it out on 2-3 day trips (1500 miles).
Also, if I go the 625 route, should I consider roller rockers?
Old Jul 5, 2017 | 05:51 AM
Yo_Boss's Avatar
Yo_Boss
Where do you want the power?
Old Jul 5, 2017 | 06:44 AM
prodrag1320's Avatar
prodrag1320
either cam will work very well in a 107",the .590`s will want 10.8-1,.625 likes 10.35-1 to 10.5-1.yes ide use r. rockers if going with the .625.
Old Jul 5, 2017 | 08:19 AM
rhuff's Avatar
rhuff
I would like it more to the left. With the 67, it comes on like a freight train at about 3100 RPM and carries all the way out to about 6K. I like that, but I wouldn't mind it coming on closer to 2500 RPM. I would like it to still have legs past 5000 RPM though.
Thanks.
Old Jul 5, 2017 | 11:07 AM
RKGDCG03's Avatar
RKGDCG03
Veteran: Coast Guard
I used a T-Man 600 in my all bore 107. It has a early closing intake and the torque is 100 ft.lbs. at 2100 RPM, max is 123 and still has 95 ft.lbs at 6000 RPM. HP max is 121.
Compression is 10.5:1, CCP is 215. I used a HPI 55mm TB with 5.3 injectors, and D and D Fat Cat with the wrapped perforated baffle, roller rockers and Baisley Super Stock heads.
I have thought about going to the 625, but i can pull the front wheel in second now. 2003 Road King.
Old Jul 5, 2017 | 11:19 AM
rhuff's Avatar
rhuff
I think with that, I'd leave well enough alone My build is definitely too soft down low and overall peak numbers were soft IMO. Hopefully, the tuner (is a builder also) is able to address some of the shortcomings of the original build IMO. At 2500 RPM, I'm at about 93 TQ. Peak tq is 115 and at 6000 RPM, I'm at 95 too. Max HP is 113.
All around, I've always been a bit disappointed with the overall quality of the power that it makes. Both peak and under the curve. We shall see what happens after it gets another CCP check. Pretty sure it will be a cam change to the 590 or the 625. A 57mm TB is going in as well as i'm getting a heck of a deal on it. Not really willing to change exhaust as I and the tuner doesn't think that is what's holding it back. Crossing my fingers. My dyno is in the dyno section FYI.
Old Jul 7, 2017 | 08:28 AM
mattVA's Avatar
mattVA
You can check the build details and there's a chart in the link in my signature. I'm very happy I went with the Tman 590. You don't have to use 10.8:1 static with this cam. I went 10.6 and still got excellent results.
Here's a link to the chart: https://www.hdforums.com/forum/engin...l#post16007568
Old Jul 7, 2017 | 09:22 AM
rhuff's Avatar
rhuff
That's a nice curve. I'm *hoping* the 590 will give me similar results. I'd love to hit 100 TQ as early as you do.
Any idea of your CCP and any issues with starting?
Old Jul 7, 2017 | 02:43 PM
RKGDCG03's Avatar
RKGDCG03
rhuff, starting shouldn't be an issue if you have compression release's. Mine will start cold with the release's closed but never hot.
Old Jul 10, 2017 | 12:12 AM
FlaHeatWave's Avatar
FlaHeatWave
The T-Man 625s work very well at 10.5-1, CCP 192-193, come on early and stay late (6k), quiet, using S&S Roller Rockers & Premium Lifters.
Another one you might consider is T-Man's "new" 585s.
