Need more umpf
Old Jul 19, 2017 | 06:31 AM
Dennis Lett's Avatar
Dennis Lett
Originally Posted by Hillsidecycle.com
Actually, no, as the 26 needs a fair compression boost to show off, but if using the Andrews cams, the 21 is the man, for an 88" plug/play application.
Scott
I currently run a 21 but my understanding is the 26 wakes up with higher compression, but it isn't needed, just gives him options for more motor work later. I like that the torque on the 21 comes on sooner.
If he really wanted to pull stumps, a big bore kit, a fair amount of head work and a 48 would really move him on down the road.
Old Jul 19, 2017 | 06:44 AM
prodrag1320's Avatar
prodrag1320
98" with S&S .583`s set @ 9.8-1 is a good option too
Old Jul 19, 2017 | 07:37 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The 26 will roll 95 hp, 105-107 ft/lbs., quite often, with instant delivery.
Scott
Old Jul 20, 2017 | 09:52 PM
ntraindavefl's Avatar
ntraindavefl
Originally Posted by Byrdogone
I have a 2000 flhtci, with 88 tc. I usually ride 2 up. I'm tired of having to use full throttle when we take off. I have true duals stage 1 breather and a pc3. Looking for cam options. I guess I'm aggressive I want it to go when I twist the throttle. Thanks in advance
Remember if you go with motor work of a camshaft or more you more than likely will need to consider upgrading your tuning device. Just keep that in mind when planning your next move.
Old Jul 23, 2017 | 12:44 PM
tootal's Avatar
tootal
All good options on here. Since you have a 2000 model you have a good crank and the run out is most likely nill or close to it. I would recommend gear drive cams. There is initial cost but when you're done there is no more worries! I also recommend Axtell's Oil Bypass Valve while you're there. It seems to lower pressure at high rpm and raises it at idle. I was really impressed at the idle pressure. It also bypasses to the cam cavity and not just back to the suction side of the pump so there isn't any foaming and sheering going on. BTW I have no connections to Axtell or Zipper's, just my experience with the product.
I'm running Andrew's 21G cams with a 95" motor with 9.2 cr and what I guess is called stage ll heads? 1.9 intakes and ported? This is a great combo. Raise the compression a little and use 26G cams would be very similar with a little more high end.
Like I said, all good stuff!
Old Jul 24, 2017 | 04:58 PM
QNman's Avatar
QNman
HMM Stage I or II Heads
HMM 98" Big Bore KIt
Andrews 26 cams
9.65 cr
GREAT straightforward touring combo.
Scott
Just because I'm curious, what would a setup like that run? My dad's got a '02 Police Electraglide.
Old Jul 24, 2017 | 05:21 PM
cdonis's Avatar
cdonis
Call hillside. Google 98 kits and you'll see , then add the headwork and cams if they aren't included. Then you'll find there is more yet. Labor of you can't do Everthing yourself.
Old Jul 26, 2017 | 11:35 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Doesn't look like the OP is coming back to read any of the responses...
Old Jul 26, 2017 | 11:48 PM
Road Star's Avatar
Road Star
Scott
Scott... I am not that impressed with the 37G cams I have in my bike - wondering if I could just drop the Andrews 26G into my current build:
98CI
10:1
Killer Carb
Daytona Twin Tec ignition
RB Racing Black Hole
no headwork
The bike currently does get up and go, but I have to really jump on the throttle; mostly upper RPM to really get it going.
Thanks! (sorry for the hijack!)
Old Jul 27, 2017 | 05:12 AM
Hillsidecycle.com
Sponsor
Along with S&S lifters and pushrods, cam bearings.....just about 2K.
HUGE gain for that money!!
Scott
