Need more umpf
Old Jul 27, 2017 | 05:16 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Originally Posted by Road Star
Scott... I am not that impressed with the 37G cams I have in my bike - wondering if I could just drop the Andrews 26G into my current build:
98CI
10:1
Killer Carb
Daytona Twin Tec ignition
RB Racing Black Hole
no headwork
The bike currently does get up and go, but I have to really jump on the throttle; mostly upper RPM to really get it going.
Thanks! (sorry for the hijack!)
That's odd.
That 37, at 10.0 cr usually hits good.
The 26 MIGHT help, some, but the squeeze it too much for it.
Have a strong suspicion that your pipe may be a bit too free flowing.
Scott
Old Jul 27, 2017 | 08:33 AM
Road Star's Avatar
Road Star
Originally Posted by Hillsidecycle.com
That's odd.
Scott
Hmmm... any recommendation on a pipe? D&D Fat Cat?
Old Jul 27, 2017 | 08:54 AM
QNman's Avatar
QNman
Along with S&S lifters and pushrods, cam bearings.....just about 2K.
HUGE gain for that money!!
Scott
Dang! Not bad! Not bad AT ALL! I'll pass it along...
Old Jul 27, 2017 | 12:29 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98CI
10:1
Killer Carb
no headwork
I believe Scott is right about your pipe. I got rid of my RB Racing LSR 2-1 and put on a Supertrapp. At 2800 rpm I picked up 20% more torque. I have 2 Dyno sheets in the dyno charts section under thread "only the beginning". Check it out. The gold line in the first chart is with the LSR and the black line is with an old E pipe. The second Dyno chart is with the Supertrapp... A gain of 16 lbs of torque is huge especially at the bottom end.... And that was all because of a pipe swap....
Old Jul 27, 2017 | 01:27 PM
Road Star's Avatar
Road Star
I believe you. Kinda bummed, gonna have to see if anyone will want to buy it.
May have to give up some sound for performance.
Is that what I need, more back pressure; restriction at the exhaust?
Not sure how the D&D Fat Cat runs - maybe better with the quiet baffle? Maybe a little more restrictive, more back pressure?
Old Jul 27, 2017 | 03:04 PM
98hotrodfatboy
You can try pm'ing member OldEnuf2NoBtr, he seems to know a little about D&D pipes.... I've never used them....
Old Jul 28, 2017 | 06:37 PM
Road Star's Avatar
Road Star
Since my compression is too high for the 26, what would be a good low end cam for 10:1? Or, am I better off changing the pistons to lower compression?
Old Jul 28, 2017 | 06:50 PM
bad tappets's Avatar
bad tappets
Originally Posted by Byrdogone
I have a 2000 flhtci, with 88 tc. I usually ride 2 up. I'm tired of having to use full throttle when we take off. I have true duals stage 1 breather and a pc3. Looking for cam options. I guess I'm aggressive I want it to go when I twist the throttle. Thanks in advance
If you're having to use full throttle to take off, something is wrong with your motor or you're passenger is obese.
chazzy
Jun 24, 2014 08:29 AM
TO34
Engine Mechanical Topics
15
May 27, 2014 05:04 AM
DRAGO'S BIKE WORKS
Vendor For Sale Classifieds
Feb 27, 2012 07:19 AM
Roy101
Sep 15, 2010 01:23 PM
wjl24
EVO
Oct 5, 2007 01:17 PM
