Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Hello
I have a 2016 streetglide and I am looking at swapping the engine out for the S&S 124ci engine or screaming eagle 120 this fall.
I am looking for some opinions on the screaming eagle 120 or the S&S 124.
questions
1. Reliability of the S&S 124 vs screaming eagle 120. I put on approximately 10,000 km per year.
2. Performance which is better, I am not a burnout or wheelie guy, but like to have the power when I want it.
3. When I upgrade my bike from a 103 to a 120 or 124, I will be replacing the exhaust, stock air cleaner and adding a programmer. should consider replacing any other partsS? I want to be able to ride without worrying if I am going to breakdown.
Neither. Have one of the reputable builders on this site build a 124 to fit your needs. It will be more reliable, fit your want better and may even be a little cheaper.
The 124 LC is great IMO. I install a bunch of them. You will need to upgrade your throttle body, injectors and clutch as well as a good exhaust and air cleaner backing plate to match the throttle body.
It also has a better warranty than the 120st
I also agree with building your existing motor to 124",for one,its cheaper.two,you retain your factory VIN #`s & three you can build it exactly to your riding style & expectations.forget the 120".
