Engine won't run
Old Aug 13, 2017 | 04:41 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by Harleyrider4090
That may be what is going on went to larger lift cams so the rollers just maybe hitting the webbing thank you Max..
BTW. It's not the lift of the cams.. It's simply the arch the roller makes under the top cover.
http://tmanperformance.com/wp-conten...ker-Relief.pdf
Old Aug 14, 2017 | 07:47 AM
Fat11Lo's Avatar
Fat11Lo
I installed S&S roller rockers in my engine, haven't attempted to fire this up yet. Could I check for this issue by pressurizing the cylinder and check for leakage at the ports? I have a leak down tester. Tank isn't on yet so now would be a good time to go back in instead of waiting until I'm trying to start it?
Old Aug 14, 2017 | 08:16 AM
jbarr1's Avatar
jbarr1
I would suggest removing the top covers and relieving the webbing per the link that Max provided. Most roller rockers do hit.
Old Aug 14, 2017 | 08:45 AM
Max Headflow
A leak test will tell you if you have the valve lifted off the seat but it won't tell you if you have any extra clearance.. You really should set the cover up so that it has at least 0.060" clearance to allow for assembly and functional tolerances
Old Aug 18, 2017 | 11:35 AM
Fat11Lo's Avatar
Fat11Lo
Cool, Thanks Max. Going to check this out this weekend. The 0.060" would a little clay be a good way to measure this? I saw a comment on anther post where you said rocker clearance was a common issue on early motors. Did castings get better over the years? I replaced my upper and lower rocker housings with new black lowers and contrast cut uppers. I did look at the lowers before I bolted them on and it looked like there was more clearance for the spring than my OE 2011 ones? One more quick question while we are on the subject of clearance. I was advised to open up the tops of my push rod tubes with a 5/8" bit so the push rod doesn't contact the tube, since I have a 0.625" lift cam, how far down the tube needs opened up?
Old Aug 18, 2017 | 04:15 PM
Max Headflow
Clay is fine. When you get right down to it part of the reason many say 0.060 is to guaranty that there is sufficient clearance do to measurement errors.
I suspect that the rocker clearance you are mentioning in another thread is for valve springs. On later bikes they still need to be checked if you are running straight wound springs.. Most later heads run beehives which typically have lots of clearance. Covers do have more space for straight spring as some of the SE heads used straight springs..
I would guess 3/4 inch to 1 inch on the depth.. They only seem to rub right at the top near the o ring ring. I'm pretty bad at this.. Kind a go "yeah that looks good" and stop. I've seen em rub on dead quiet motors so I question it's value but do it anyway..
Old Aug 20, 2017 | 07:03 AM
Fat11Lo's Avatar
Fat11Lo
I'm gonna guess that rocker arm clearance isn't going to be a problem with these covers
Opened up the push rod tubes with a 5/8" reamer I had
As always Thank You Max for taking the time to answer my questions
Spur56
Feb 9, 2012 02:10 PM
HoggyMtnBreakdown
Exhaust System Topics
Aug 20, 2011 08:59 AM
XMA
Sep 18, 2010 01:41 PM
Duke of HD
Jul 13, 2009 09:53 PM
gooberhd1
Nov 6, 2007 10:53 PM
