Compression release
Old Aug 14, 2017 | 08:04 PM
hillclimber1's Avatar
hillclimber1
Default Compression release
Does my 2012 Ultra classic have a compression release? If so, how do I check it for correct operation? My starting problems seem to be too much compression??? My battery checked out ok. Starter won't quite turn it fast enough to start when engine is hot.
Old Aug 15, 2017 | 12:44 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Yes it has compression releases. Bend down and put your head near the bottom of the gas tank and then turn the ignition switch to run, you should hear a small click. That will be the releases opening up.
Old Aug 15, 2017 | 03:36 PM
hrdtail78's Avatar
hrdtail78
Perform compression check. Pull fuse or disconnect compression releases. Redo compression check.
grieker
Oct 13, 2014 08:03 PM
1977f150
Exhaust System Topics
Oct 21, 2009 04:18 PM
natural gasser
13
Jul 15, 2008 04:58 PM
05 HD Deluxe
Aug 12, 2007 10:21 AM
JeffreyLebowski
Sep 20, 2006 11:00 PM
