Valves
Old Aug 23, 2017 | 12:45 PM
TSwann's Avatar
TSwann
3rd Gear
Default Valves
I recently put new valves and springs on my 97 wide glide. I put those in because I was getting a loud clicking, louder than it should be. Which led to something getting stuck in the rear cylinder, I thought it might just be the valves and springs. Once the new ones were in I made it about 20 minutes on the test ride. Then the clicking started back up and the. Some thing in the rear froze up again. I've disassembled the cylinder and the rocker arms are good the pushrods are fine. So the problem must be in the head. What's wrong?
Old Aug 23, 2017 | 02:00 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Are you saying that one of the valves will not open.? That it's seizing in the guide? Is it possible that the valve stem diameter is larger than the OEM valve causing it to set up when hot...? Was it doing this before you replaced the valves?
Old Aug 23, 2017 | 02:26 PM
TSwann's Avatar
TSwann
3rd Gear
I'm pretty sure the valve was getting stuck. But after I dissed emblem the head the valves moved around just fine.
Old Aug 23, 2017 | 04:17 PM
98hotrodfatboy
After they cool they will... It's only when they get hot is when they will drag. Can you still turn the motor over after this happens when hot? Cause if it was a stuck valve you shouldn't be able to turn the motor over.....
Old Aug 23, 2017 | 05:13 PM
TSwann's Avatar
TSwann
3rd Gear
Ya motor wouldn't turn when at temp. Do I need to replace the valve guides?
Old Aug 23, 2017 | 09:19 PM
Max Headflow's Avatar
Max Headflow
Put in new lifters. Problem is that they as they get older they end up bleeding too much and drop the valves on the seats hard. You hear the tick. Adjustable pushrods can help as you want the preload to be about 0.140
Old Aug 24, 2017 | 05:38 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I agree with Bruce.
Another pointer;
If the new valves have a larger stem diameter(doesn't take much at all, .0005" can do it) they can/will grab the guide ID when warm, and chances are that scoring will occur.
The guide and stem clearence NEEDS to be adhered to, via precision machining/measuring.
Scott
Old Aug 24, 2017 | 09:43 AM
TSwann's Avatar
TSwann
3rd Gear
Ok but it did the same thing witht the old valves. Do I need to hone out the guides and new seals or new guides and new seals?
Old Aug 24, 2017 | 11:52 AM
98hotrodfatboy
Sometimes you need to visit a local Indy for them to be able to help you and figure it out. Most will offer good advice but will still need to dig into it to confirm what's causing the problem... Paying for a test ride and diagnoses is sometimes the best way...
Rodewarrior1981
Shovelhead
16
Sep 8, 2018 10:37 PM
ewoods8393
Jun 10, 2015 10:38 AM
Schulte94
EVO
26
Oct 24, 2013 09:20 AM
dan61t
Apr 24, 2012 07:24 PM
mbierbac
Exhaust System Topics
26
Nov 16, 2011 08:45 PM
