1952 Pan Head assembly HELP!!!!
Old Aug 23, 2017 | 01:18 AM
dasr12006's Avatar
dasr12006
Default 1952 Pan Head assembly HELP!!!!
Who knows these motors? need help with thrust washers on crank.
Old Aug 23, 2017 | 03:54 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
They come in different thicknesses, for that flat-bearing assembly, and if need be, can be custom ground, as needed on a surface grinder.
Make sure you de-magnetize once completed.
Scott
Old Aug 23, 2017 | 07:13 AM
prodrag1320's Avatar
prodrag1320
which one to use is really not hard to calculate,figure your end play.subtract in your clearance and divide it by two.get spacers that thickness
Old Aug 23, 2017 | 09:33 AM
dasr12006's Avatar
dasr12006
sorry, I had a big long post typed out and the website timed out while I was uploading pictures.
I took this engine apart in 1997 as a project with my father to freshen it up, it never went back together. Im trying to put it back together now but I am stumped on where the thrust washers go. I have what I thought was a factory shop manual but its not...... I MIGHT be missing a washer. the diagram in the book shows 4 possible thrust washers aside from the 2 with the pin hole that go on the crank first. This manual also shows the washer with the tab going into the bearing race which just wont work......... unless I'm supposed to angle it in there all weird.
Attached Thumbnails 1952 Pan Head assembly  HELP!!!!-20170822_181228.jpg   1952 Pan Head assembly  HELP!!!!-20170822_181211.jpg   1952 Pan Head assembly  HELP!!!!-20170822_183350.jpg
Old Aug 23, 2017 | 09:37 AM
dasr12006's Avatar
dasr12006
#10 and #25 are onthe crank correctly, the bearings are on the correct side. I am confused with that thick washer that I'm holding on the crank. Not sure where that goes. I have washer #29 and a washer that appears to be indentical minus the tab and that fell out of the left side engine case when I was cleaning it so I am pretty certain that goes in there. The washer that is shown between the 2 needle bearings on the left side might be missing. There is 1 video I found on youtube of a shop putting together a 49 and he puts the bearings on and, nothing more than I can see aside from #10 and #25 and the slaps the case on.
Old Aug 23, 2017 | 10:12 AM
dasr12006's Avatar
dasr12006
regarding the 2 bearings that are stacked on the left side, looking at the wear on the bottom of one and the top of the other suggest that there was no washer in between. I have no idea of the history of this bike, it may have been apart before my father got in the early 70's.
Old Aug 25, 2017 | 12:12 PM
dasr12006's Avatar
dasr12006
No one??? weird.
Well, I think I have it figured out by process of elimination and looking at various diagrams.
MCT
Audio Systems
Aug 21, 2013 05:23 PM
gopherdave
Aug 19, 2011 11:00 PM
its-an-old-thrasher
Mar 25, 2011 09:05 AM
arachman
General Topics/Tech Tips
May 16, 2008 05:05 PM
oakley
Mar 22, 2007 08:45 AM
