Help with generator
Old Aug 19, 2011 | 07:39 PM
gopherdave's Avatar
gopherdave
2nd Gear
Default Help with generator
im new with harley and picked up a 1975 sportster anyway i need to replace the generator only im not shure wher it is and how to do it thanks
Old Aug 19, 2011 | 07:55 PM
Scuba10jdl's Avatar
Scuba10jdl
Frankly, if you don't know where it is or what you are going to need to do, you really should not be working on it.
Get a service manual, read it, and then see if you are still up for it.
Old Aug 19, 2011 | 10:24 PM
gopherdave's Avatar
gopherdave
2nd Gear
Default i hate to sound smug
well i dont have a book right now im getting one some friends told me what it was and wher it is is and i thought someone could help as far as tools i think out of my 10000.00 in snap on i should find some thing to work maybe a pair of vice grips and a hammer. i do have a 1970 firebird formula that runs solid 9's so i think im up to the job
thanks for the smug answer
Old Aug 19, 2011 | 10:31 PM
mikeallenbrown's Avatar
mikeallenbrown
I don't think it was a smug answer at all .... neither Scuba nor I nor anyone else knows how much mechanical know how and/or experience you have. Mechanic 101 says you need to have a service manual at the least. He is right on when he said read the manual first and then think about whether you really want to do it or not.
If anything his answer was direct and to the point. Just my two cents worth.
Good luck on that generator.
Old Aug 19, 2011 | 10:45 PM
gopherdave's Avatar
gopherdave
2nd Gear
Default help
well i guess myreply was just a product of a bad day at work and i just wanted to get started on the harly befor the 10 days is going to take to get the manule
Old Aug 19, 2011 | 10:55 PM
pococj's Avatar
pococj
Front of the engine cases, down low, two wires (sometimes more depending on how many previous owners rewired it!). Disconnect battery, disconnect the leads on the generator, remove 2 long bolts (on right side of engine) holding genny to engine.
After installing new genny, polarize it! That's where you need the manual, or go into the "Classics" section here and search for a great how-to on the polarizing process.
Old Aug 19, 2011 | 11:00 PM
mikeallenbrown
Understood ....we've all been there!
Cheers!
MCT
Audio Systems
Aug 21, 2013 05:23 PM
Tampa Fatboy
Mar 29, 2012 09:04 AM
Medic192
Nov 13, 2011 01:47 AM
midnight2005
Aug 19, 2010 05:02 AM
12Stones
General Topics/Tech Tips
11
Nov 18, 2004 03:40 PM
