Dynatek 2000i
Old Sep 9, 2017 | 07:28 PM
JesseLeonard's Avatar
JesseLeonard
Stage III
Default Dynatek 2000i
Ok guys, having some trouble with getting my bike started. I have a 2004 APC with a REVTEC motor 100 cubic inch. Not getting spark. Replaced coil, starter is good,spark plugs are new and we rewired the entire bike. Also gave it a new brain. I have the mode switches all off except the 6th position. It is also set with single fire. There is no spark. Can anyone offer a solution? Thanks, Jesse
Old Sep 9, 2017 | 08:52 PM
bustert's Avatar
bustert
does it have a led on the module?? does it blink when cranking??? if it stays on then there is an over-load some where and the module shuts down.
make sure the ohmage is correct or it will over drive the ign.
Old Sep 10, 2017 | 09:57 AM
JesseLeonard
Stage III
Yes it has led. No it was not blinking. Only the green light stays on. We reversed the pink and blue wires to coil since it says it will give it a better spark. No spark. Tested white wires and they have 12v coming in but going out reads 6.9. we have curve set to 1 as we have always had it that way. What else you got? ... Thanks for helping us out! And thank God we have a #2 bike!
Old Sep 10, 2017 | 11:36 AM
bustert's Avatar
bustert
if you are not getting the red light to blink, there is no trigger. is your timing cup secured and correct for application?
the switching of the primary wire is only if the coil mounting forces you to say invert the coil. the pink must always be in rear position and blue forward, if this is not the case, then the cyls will fire out of order.
when you turn on power, the red light will turn on 1/4 second for a self test, indicates it passed. now if the timing cup is in the firing range, the led will blink and stay on.
if it flashes rapidly engine off, there is an over-load possible short or wrong coil.
engine running the led will flash 45* before tdc and go off at tdc each cyl.
you are running the right coil??
green says power, no red no trigger. as a redneck test, remove module and wave a metal object between the pick up slots and see if the red will blink, test both pickups.
Old Sep 10, 2017 | 10:34 PM
Max Headflow's Avatar
Max Headflow
How do you tell whether a wire has 12V going in and 6.9 coming out?
White wire and coil need 12V.. Pink and blue should be sitting at 12V with the ignition on and motor not cranking. If not then the module is likely smoked.
Did you forget to install the rotor cup?
Old Sep 11, 2017 | 05:58 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
As a rule, those Dyna 2000i ignitions are very solid.
Scott
Old Sep 11, 2017 | 07:31 AM
bustert's Avatar
bustert
missed the white wire part. like was said, 12v on white coming from ign power, coil terminals will be at 12v since the ign mod grounds the other side to charge the coil. if the power at the mod white is that low, it will not work. redneck test is to remove mod white and place on a good 12v source and see if you get spark, if not, mod is probably toast.
i did have one failure from them but i do take it to the limits 7.5k rpm.
Old May 27, 2018 | 02:58 PM
UncleBill's Avatar
UncleBill
1994 springer softail.
S&S E carb, voes connected, single fire.
New dyna 2000I module (replacing a worn out HI4)
Bolted into the cone and wired.
Running rough at low rpm. Trying to find the problem.
Question 1: The green light on module is always blinking.
Can flip the dip switch on and off still blinking, runs the same with dip switch on/off.
Is module OK ?
Can you think of some other area I should be looking.
P.S. Friend thought maybey a leak at manifold/head or carb/manifold. Can find no leak.
Old May 27, 2018 | 04:29 PM
UncleBill's Avatar
UncleBill
Update on my post above.
Green led no longer blinking. (with dip switch 1 off)
Tried curve 1 and curve 2.
Disconnected purple wire at connection between tanks. (purple dynatek wire to green HD voes wire)
Plugged vacuum tube at the carb.
And, same chit. Don't matter what I do. Runs like chit.
Hook the voes back up, curve 1, curve 2..no help.
Missing and sputtering like a engine out time at low RPM, no load.
Outta ideas...
Old May 27, 2018 | 08:20 PM
Max Headflow
Does one cylinder get hotter than the other?
