Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Hey there Gents. I have been looking for a place to have some custom cams made for early twin cam. I found a cam that I like but it is for 07 and up and am not interested in the conversion cams. any suggestions as to where I can get some ground? I don't care where they are in the United States as long as they are reputable.Thanks
Don't know anything about them but maybe Black Widow Cams?
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
Delta Camshafts, I had these guys do me a custom grind for a subaru motor I built. My cousin had them do a custom cam for his 1970 Mach 1 Mustang. I'd give them a call it's what they do, I'm sure they can do cams for anything.
These are the people that I thought of first and looked them up on Google but it seems that I am unable to find their website for some reason. Are they still going?
I would also get pricing for the conversion. Grinding a one off cam once isn't cheap.
