Engine problems in Orlando
Old Oct 26, 2017 | 06:12 PM
Ryan777's Avatar
Ryan777
1st Gear
Default Engine problems in Orlando
Hey guys, just wondering if any does work on the side. My 01 Roadking seems to have several leaks and was wondering if someone in the Orlando area has time to work with me and help me take out the engine and fix the leaks??? thanks, Ryan
Old Oct 26, 2017 | 06:25 PM
QC's Avatar
QC
Welcome to the Forum from Colorado!
While there probably is someone able to help you, I suggest you pick up a Harley Service Manual for your bike and do the work yourself. They are not very complicated machines.
Good luck.
Old Oct 26, 2017 | 06:45 PM
Ryan777's Avatar
Ryan777
1st Gear
Thanks, I am pretty mechanical but I just didn't want to get in over my head and not be able to get it back together.
Old Oct 27, 2017 | 04:38 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
In the immediate Orlando area, Doc's Performance Tuning, in Deland, VeeTwin Racing.
Scott
Old Oct 27, 2017 | 12:43 PM
djl's Avatar
djl
Describe the leaks, maybe include some photos. Not sure you have to "take out the engine" to address the leaks. If you have the service manual, decent set of hand tools and 5 on a 10 scale of mechanical aptitude, this could easily be a DIY repair.
Old Oct 27, 2017 | 01:07 PM
Ryan777's Avatar
Ryan777
1st Gear
Well there seems to be one one the lower side of the engine. I tightened all the bolts on the bottom pan
but it still leaks. Also I have a new one close to the top on the rear cylinder. I took it to the dealership close to my house and they wanted $1000+ to replace some gaskets. I have a repair manual so I guess I will tackle it when I have a few days off in a row. I know the second picture doesn't show much but that is about how much it leaks.
Old Oct 27, 2017 | 02:32 PM
djl's Avatar
djl
The leak in the first photo appears to be a leaking rocker box gasket or loose fasteners; easy and inexpensive fix. The leak in the lower photo is could be coming from the inner primary or one of the seals behind the trans pulley.
How many miles on the bike? How does the leak present? IAW, does it leak for a while after a ride and stop or does it leak continuously while parked?
Suggest that you take some brake clean or hit the car wash and clean the under carriage as well as the area between the primary and the motor case, particularly the area around the trans pulley. Also check the trans fluid level. If you don't have the OEM service manual for you bike, suggest you get one ASAP.
Old Oct 27, 2017 | 02:48 PM
Ryan777's Avatar
Ryan777
1st Gear
only 27000 miles on it. I will check what you said and reply back. It is just a very small continuous leak, maybe one ounce a month at most. Thanks a lot for your help with this maybe it will save me a lot of money I don't have. Ryan
Old Oct 27, 2017 | 07:13 PM
Ryan777's Avatar
Ryan777
1st Gear
ok, I might have fixed the top leak. I took off the tank, then the valve cover and the rocker cover bolts were extremely loose. I tightened them all to spec so hopefully it will fix it. I will tackle the lower ones next. Thanks again DJL!
Old Oct 28, 2017 | 07:08 AM
Hammerhead Pat's Avatar
Hammerhead Pat
There you go!! Hope that solves that issue, and you get the satisfaction of knowing you did it yourself!!! Good luck with the other leak....
Phunky One
Dec 11, 2018 07:49 AM
wcm413
Oct 20, 2013 01:26 AM
whiteycracker
Welcome Area Only
Jul 11, 2012 01:13 PM
gforceman2
Feb 3, 2010 07:50 PM
Raptor1956
Feb 6, 2009 04:25 PM
