Andrews 21 or 26?
Old Dec 29, 2017 | 06:18 PM
JP7's Avatar
JP7
Default Andrews 21 or 26?
Well it's supposed to be -11 tonight so guess riding is out for a while. That means it's time for improvements. I can't decide which cam I want. The Andrews 21 or 26.
I have an 03 Electra Glide Classic with 95" kit, Rinehart True Duals, and Screamin Eagle air cleaner. I ride two up about half the time. I enjoy the torque but it does see 5,500 frequently. The heads are stock for now but I may have them ported in the future. Let me know your thoughts on these two cams or any others you think would fit the bill.
Oh yeah, I have the stock cam plate and oil pump with the baisley spring. I'm not interested in changing those at this time. Thanks for the input.
Old Dec 29, 2017 | 06:33 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Do the 26, it'll carry out a little better for you... whats your Static compression? the 26 cam likes 9.8 -10.0:1 static.
Old Dec 29, 2017 | 07:52 PM
JP7's Avatar
JP7
It's 9.5 for now. I could bump it up some if I do the head work.
Old Dec 29, 2017 | 08:28 PM
98hotrodfatboy
What kind of headwork are you considering?
If your gonna do like a stage II head, then I would probably look at different cams like maybe the Andrews 54 or others... Doing stage II opens the door to a lot of cams cause now the heads can handle a lot more lift and don't forget that porting is a nice upgrade... It might be time to talk to a good porter.... He'll match the heads to the cam.
Old Dec 29, 2017 | 08:43 PM
JP7's Avatar
JP7
Not planning on anything crazy on the heads, just a CNC street port and maybe bump the compression a little. I want to stay on pump gas and and reliability is more important than a torque number.
Old Dec 29, 2017 | 08:53 PM
lightweight bob's Avatar
lightweight bob
Looking where you're at now and your occasional 5500 rpm buzz I'd be going with
Andrews 37 - had them in an 88 bagger and loved it. My 2013 flhtk 103" bagger has
a 57 in it - same cam timing but .050 more lift for the extra cubes. Same riding as
you - two up some of the time and an occasional solo blast around by myself. Stock
springs are ok but replace those cam bearings for sure. http://www.andrewsproducts.com/sites...fs/page_06.pdf
Old Dec 29, 2017 | 09:45 PM
sbaumann14's Avatar
sbaumann14
-11? I'm in Rhinelander and its only supposed to get to -5...lol! I put 21's into my 03 Heritage springer this summer and couldn't be happier. I ride 2 up all the time and with a trailer 50% of the time, so I wanted the torque. also did the hydraulic upgrade while I was in there.
Old Dec 30, 2017 | 01:00 PM
djl's Avatar
djl
Change the springs and set them up for .625" lift; many more cam options to choose from. '03 springs are limited to advertised .510" lift but most will accommodate cams with .525" lift which does limit cam choices. Since the beehive springs were introduced in '05 most of the newer cams are higher lift cams. Don't cut yourself short on the head work. If the bike is EFI, good fuel management and dyno tune should also be part of the plan. BTW, you should make the compression decision before the headwork and select a cam set or at least the range of intake close timing so the heads can be decked, if necessary, to set compression at the target level.
Old Jan 2, 2018 | 04:52 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Our Stage I Head, with the compression set at 9.7 with that 26, is a home run.
Build 5-7 of that combo on an average, each year.
Scott
Old Jan 2, 2018 | 06:50 PM
JP7's Avatar
JP7
Scott
Any benefit to using the later model heads Scott? I see them for a pretty good price around here.
