Breather ????
Old Jan 9, 2018 | 08:27 AM
djl's Avatar
djl
The breathers the OP has per his pics are the later stamped assemblies which were introduced in the 2011 MY; the pic from the parts manual are the early two piece aluminum breathers. The OP didn't specify his MY but assume it is an '08-'10 as those are the on years he mentioned in his post. The previous owner upgraded the breathers to the more efficient stamped breathers. I would not run without them, external venting or not but that's JMHO.
The stamped breathers are re-buildable but at $12 per, why bother, just replace the whole assembly.
Old Jan 9, 2018 | 08:29 PM
Big Dave's Avatar
Big Dave
Thanks djl my bike is the 09 ultra
Dave
Old Jan 9, 2018 | 08:59 PM
Big Dave's Avatar
Big Dave
Board Tracker $12 usd
Canadian funds plus international shipping comes to just under $50 cdn each
Hope my cam kit has the right parts to repair
Dave
Old Jan 10, 2018 | 08:46 AM
djl's Avatar
djl
Originally Posted by Big Dave
Board Tracker $12 usd; Canadian funds plus international shipping comes to just under $50 cdn each. Hope my cam kit has the right parts to repair .Dave
A cam kit won't have any breather parts included. Get a buddy in the lower 48 to buy the parts and mail them to you.
PNs are 17025-03A for the complete assembly including the shorter bolts and 26500002 for the baffle assembly (breather valve and filter which is all you really need); the baffle assembly goes for about $6.00/each.
Old Jan 10, 2018 | 08:58 AM
Fat11Lo's Avatar
Fat11Lo
Dave
Where did you get your cam kit?
I bought one through my dealer once and it had them included, plus a whole other bunch of crap I didn't need.
Old Jan 10, 2018 | 09:02 AM
98hotrodfatboy's Avatar
98hotrodfatboy
If it helps I found these for under $30.00 on eBay...
https://m.ebay.ca/itm/Genuine-Harley...0AAOSwJs1ZvRfv
Old Jan 10, 2018 | 09:10 AM
djl's Avatar
djl
Those are the umbrella valves for the early two piece OEM breathers; different PN so not sure if they are the same as the valves for the stamped breather but could be. The HD bean counters would probably insist that the later stamped breathers use the existing umbrella valve to protect the bottom line.
Old Jan 10, 2018 | 10:53 AM
98hotrodfatboy
Crap I think I missed the boat, again.... Thanx djl...
Old Jan 10, 2018 | 11:43 AM
hrdtail78's Avatar
hrdtail78
Umbrella valves: James Gaskets PN 26858-99 fitment 99-17. Cometic PN c9633 fitment 99-17.
Old Jan 10, 2018 | 02:44 PM
djl's Avatar
djl
As I thought but was not sure; thanks for clearing that up.
