Help on Milled Heads
The contact will usually be on the intake side as TDC lift is higher and the OEM valve reliefs are not cut out toward the edge of the piston enough; see the attached pics for clarification. It is a hit/miss proposition and, as has been pointed out, one that should be checked carefully; you can ding a valve real easy. If you have to open up the valve reliefs, you can do it with the pistons in place with a Dremel tool and the right attachment. Of course, you will have to seal off the piston to wall "gap" to insure that no shavings can enter the cylinder bore.
You should carefully remove the heads being replace and secure the cylinder to the crank case to avoid disturbing the cylinder to crank case o-ring seal.
If boring to 95", SE cast flat tops; no worries about crank balance.
If boring to 98", CP/Carillo would be my choice; the Bullet series. I would also order the heavy wall pin to match the weight to the OEM piston to maintain the factory crank balance factor. IIRC, the pin that comes with the piston is about 45 grams lighter than the heavy wall pin which makes the standard CP piston/rings/locks/pin weight about that much lighter than the OEM piston assembly; or less than 10% lighter than the OEM piston assembly. I have been told by someone who knows that a variance of less than 10% should not affect crank balance so even with the standard pin, crank balance is probably not an issue.
The only reason I mention this is that I learned this lesson the hard way; the story of my life.
I have to say, now that you are on this path with possibly more displacement and ported heads, why not consider upgrading that cam chest with a better set of cams, CYCO tensioners and new inner/outer cam bearings? You will also need fuel management and a proper tune. You are about to go down the rabbit hole.
As for the cams, I have been considering going with a better set. They were installed before I got the bike along with what you mentioned - inner/outer bearings replaced and CYCO tensioners installed. So I would really just need to replace the cams.
If I went with a 95" bore, SE cast flat tops, kept the SE-203 cams, and used my buddies heads - .054 shaved, ported, and big valves/springs - What else will I need to consider moving forward? Fuel management won't be needed as it is carbed and carb tuning won't be an issue.
As has been suggested, it would be wise to have the heads broken down, cleaned up and guide seals replaced.
You will probably get suggestions to toss the OEM cam plate and replace it with one of the SE billet upgrade kits with hydraulic tensioners, roller chains and higher capacity oil pump. If you have the $$ laying around, why not; however, you don't NEED it. I ran a strong 95" in an '05 softail with the OEM cam plate/pump and geared cams for years with no issues; your call. As part of the machine work, I would have manual compression releases installed in the ported heads; cheap and will extend starter and battery life. I would also measure deck height and consider trimming the cylinders to 0.00" deck height depending on actual and how the math works out when calculating compression. You will need to know deck height to do the compression math.
Fuel management is just part of the tuning process, you should replace the OEM ignition module with a programmable piece like the Daytona TwinTec TC88. The OEM ignition module is not programmable and the factory timing settings will not be right for the new motor configuration.
Lots of good cams available if you decide to replace the SE203s but you are working with a fixed data point which is the chamber volume and you will have to make the cam selection based on the math. Two that come to mind to look at are the S&S570 and the Andrews 57, cams with an intake close in the 36*-40* range. You should also verify the lift that the springs in the ported heads can accommodate; they are probably OK for the cam mentioned but don't guess, measure.
. Whats your reason of fear with big bore kits ? Considering they were done by a reputable shop.. .prodrag,hillside etc?
Thanks again for all the help guys!
