Help on Milled Heads
Old Feb 22, 2018 | 09:04 AM
  #41
djl's Avatar
djl
Originally Posted by John E Heikkila
I selected -1.00cc dome volume out of ignorance, BigBoyz says flat top pistons range from -1.0 - -1.5 so I selected -1.0. I do plan to cut the cylinders to a 0.00" deck. I would love to swap the cams, I really do not care for the SE-203's, unfortunately the ole lady is trying to pull in the reins on the cost of this project. If the stars align, I may be able to sneak an additional $300 for the cams. However, lets say that doesn't happen and I then plan to replace the cams next winter, what is the worse that could happen running a higher static compression with the 203's? If it could mean ruining the motor, maybe I just slap an OEM head gasket on for now to lower the compression and then next winter I can swap the cams and the head gasket?
I was measuring the valves last night, the intake measures 2" and exhaust measures 1.615", seems a bit higher than the average over sized I have been seeing in the forums. I am not sure if that changes a few factors or not?
The valve sizes are not OEM which is not the BigBoyz port job and a customer requested an "upgrade" to Bean's street port job but also means that you will have to have the valve reliefs opened up.
My comments regarding compression and the SE203 cams is based on my experience with SE204 cams which is not a fair comparison. The SE204 cams have an intake close 2* earlier than the 203s and also has 8* advance ground into the intake and exhaust profile where the 203s have 1.8* ground in advance. The larger valve reliefs will help with bring down compression as they will be 2cc-3cc now instead of 1.5cc; you should check with Scott on that. You may be OK with the 203s at 10+:1 static compression, I can't and wouldn't want to say for sure having never run the SE203 cams at that compression. However, I do suggest that you only run premium fuel and listen for ping and be prepared to back out some timing to address any detonation should that become an issue. Good luck and let us know how it turns out.
I would still toss the SE203 cams at the first opportunity and replace them with a better choice; still like the S&S570 or the Andrews 57 which I believe is available for early chain drive. It is not listed in the catalog but is available, just have to call to order.
Old Feb 22, 2018 | 08:20 PM
  #42
cody.a.e's Avatar
cody.a.e
I can 2nd the S&S 570 push. LOVE mine, especially now in my 95".
Old Feb 23, 2018 | 07:25 AM
  #43
John E Heikkila's Avatar
John E Heikkila
I have the woman on board for replacing the cams with an S&S 570. I am just waiting on the pistons to be delivered and then I will be tearing her down and bringing everything to the machinist. I am excited to see how this all turns out!
Old Feb 23, 2018 | 10:14 AM
  #44
John E Heikkila
Going with the S&S 570, part number 330-0003 states that I need a high lift spring kit. Did you require these? If so, what did you get?
Old Feb 23, 2018 | 10:45 AM
  #45
cody.a.e's Avatar
cody.a.e
I did not require them because I have '06 heads which are said to be good to around .590 lift. 99-05 heads with OEM springs need hi lift springs in order to run the S&S 570. What year are the heads you were planning on using? Also, I thought in your first post you said the heads were rebuilt with new springs. Do you know what springs they are? They might work. If I were going to replace the springs in though, I'd get the S&S .585 springs (p/n: 900-0594). They can be had on ebay, new for around $98.
Old Feb 23, 2018 | 10:49 AM
  #46
cody.a.e's Avatar
cody.a.e
http://www.bigboyzheadporting.com/showthread.php?t=83
This article will show you how to check the heads to see the casting date if you don't know what to look for.
Old Feb 23, 2018 | 11:21 AM
  #47
djl's Avatar
djl
Actually, the valve springs in the '05 models were changed to beehives and will accommodate lifts up to .600" provided checking for coil bind first; .570" is safe. '05 heads also had 7mm valve stems and some had shitty guide seals which leaked oil.
As Cody suggests, check the casting number but since the heads have been worked, the casting number may not mean much. Have your head guy check valve lift and valve stem diameter; he should know what to look for. Plenty of replacement options if new springs are required for the higher lift, just keep seat pressure close to that of the OEM beehives and avoid high spring pressures which will just add to valve train noise. I forget what the seat pressure of the OEM beehive springs is but you don't need much more than that in an aftermarket spring. The S&S .585" springs might be fine and might be cheaper than OEM; not sure about that or the seat pressure though.
Old Feb 23, 2018 | 11:24 AM
  #48
Max Headflow's Avatar
Max Headflow
99-04 heads need the tops of the valve guides cut to support the lift more than they need springs. Collars will hit the valve seal if not done.. 05 used the same 7mm valves, guides and springs as the 06 up heads so that can support 570 lift.
Old Feb 23, 2018 | 12:29 PM
  #49
John E Heikkila
I will need to have my head guy take a look. I know the valves and springs were upgraded and I know the sizes of the valves but nothing about the springs.
Tholliday
Engine Mechanical Topics
13
Jul 14, 2017 01:09 PM
Joker65
Exhaust System Topics
Jan 30, 2012 06:51 PM
bagger76
Dec 7, 2010 07:14 AM
Night Hog
Feb 5, 2010 02:09 PM
softail99custom
EVO
Jan 21, 2010 08:45 AM
