Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Got a '72 Shovelhead laying around. Has been converted from side-oiler to end-oiler by PO. Currently using a chrome cam-cover stamped with 25214-82. Now looking to change out the cover because of corrosion on the cover and what looks to be worn bushings.
So from what I understand, I should be able to use a 73-92 cover after drilling a new oil-feed hole in the cover? Any other modifications needed?
I've added some pics of my current cover and engine-case.
Thought about that. But then I have to buy the bushings, get them line-reamed, re-chromed and everything. Seems like it would take a lot more work and money to it, instead of buying a nice cover with good bushings.
