CAM burrs
Old Apr 19, 2018 | 05:03 PM
Exoskeletal's Avatar
Exoskeletal
Default CAM burrs
An S&S MR103 cam that has a lot of burrs.
Old Apr 19, 2018 | 05:43 PM
cdonis's Avatar
cdonis
Cool paperweight👍
Old Apr 19, 2018 | 06:00 PM
Campy Roadie's Avatar
Campy Roadie
Is that new ?
New or not, that ain't good.
Old Apr 19, 2018 | 08:43 PM
Exoskeletal
Brand new S&S MR103CE cam, packaged on 3/26/2018. This was the worst one. The other one wasn't too bad, it only had some chips in the teeth. :/
Old Apr 19, 2018 | 09:08 PM
bustert's Avatar
bustert
if they are new, then sloppy quality control, harmful, naw.
just go ahead and clean them up. after the pour, the profile is supposedly precision ground to spec's. this is just burn-over from the process.
Old Apr 19, 2018 | 09:23 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Call S&S, Send them back and get new.
Old Apr 19, 2018 | 09:43 PM
marcodarq's Avatar
marcodarq
Contact S&S
M
Old Apr 19, 2018 | 09:47 PM
QC's Avatar
QC
The deburr guy took the day off on that one. Yuck.
Old Apr 19, 2018 | 11:24 PM
Exoskeletal
i had considered it at first because I have the tools and some experience gunsmithing and metal working. Unfortunately, when I examined the other cam there were chips in the sprocket teeth. I've seen steel crack and fail and this set of cams just has too many red flags.
Fortunately they will take em back and refund. I might give S&S another chance but to be honest that kind of sloppy is disappointing from a joint I have looked up to for a very long time.
Old Apr 21, 2018 | 12:20 PM
martinj's Avatar
martinj
You made the right decision. If it were only a few burrs a little work with a Roloc disc would clean it right up, but the chips in the teeth are a different matter. S&S needs to own this--they're definitely better than that. Those cams should never have made it into a box.
