07 Ultra update.
Old Jun 16, 2018 | 06:19 PM
LJH1968's Avatar
LJH1968
1st Gear
Default 07 Ultra update.
Got the cam plate bolt out and reassembled bike with a functioning in/lbs torque wrench. Now I have a tapping in the motor that increases with slight throttle. I have 32psi oil press and I adjusted the push rods 3 turns (per instructions) with cylinder on TDC and waited for lifter to bleed down. Did this twice to each cylinder. Still has tapping noise. I also notice a slight oil leak on one of the tubes under the cap.I am going to inspect and see if I may have damaged an O ring. Any suggestions on the push rods? Should I go 3.5 or maybe 4 turns? Thanks to all. Thanks to all for advice on cambolt thread.
Old Jun 16, 2018 | 07:50 PM
memphisharley's Avatar
memphisharley
how many TPI are the pushrods.
the FM adjustable I am running are 32 TPI and I have them adjusted at 4/3. quiet as stock.
Old Jun 23, 2018 | 08:31 PM
LJH1968's Avatar
LJH1968
1st Gear
Cool 07 Ultra update
24 tpi. I have them at 4 turns. the noise stopped at idling. I have around 40 psi oil pressure. took the syn3 out of engine and put regular HD360 20w50 in it. Still have a tapping during throttle but it doesn't seem to increase.
Old Jun 24, 2018 | 12:26 PM
djl's Avatar
djl
At 4 turns with 24TPI, preload is about .165". General rule of thumb for preload is .135"-.140" for quiet valve train so more preload isn't going to help quiet things down. The oil change was good move, the HD20W50 is actually a good lubricant. What lifters? How many miles? Have you checked the rocker shafts for witness marks which would indicate movement and noise? A set of Rocker Lockers will solve that problem if it exists. What cams? Some with fast ramps are just noisy. Did you adjust with pistons at TDC on the compression stroke? Run all that to ground and if the noise persists, learn to live with it.
Old Jun 24, 2018 | 07:17 PM
ROCKOUT Rocker Products
Sponsor
Sometimes, after a cam change it takes a while for the lifters to get happy again. It's not uncommon to hear that guys ride 5 miles before everything quieted down. Maybe it just needs time.
If the noise is upstairs, there's a cure for that
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Bowhunter61
Sep 21, 2014 01:18 AM
cajun1957a
Shovelhead
Jun 29, 2014 08:18 PM
iflyguns
Aug 15, 2009 09:38 PM
ywhat2000
Exhaust System Topics
Jul 8, 2008 04:44 PM
harley_rd_king
Oct 14, 2007 02:08 PM
