Shovelhead whine. Sounds like cam and pinion
Old Jul 3, 2018 | 01:49 PM
Peterbuchberg's Avatar
Peterbuchberg
6th Gear
Originally Posted by Hillsidecycle.com
My 1967 FLH has had a slight whine, more noticeable on decell, for the past 30 years.
Scott
this is not a slight whine as you can hear in the video
Old Jul 3, 2018 | 02:43 PM
bustert's Avatar
bustert
http://www.andrewsproducts.com/sites...fs/page_19.pdf
might be useful if you do not have it
Old Jul 4, 2018 | 04:15 AM
Peterbuchberg
6th Gear
Thanks , I have read that one 😎
Old Jul 4, 2018 | 08:15 AM
wfolarry's Avatar
wfolarry
Do you have the right gear for the model year? There were two different sizes used on Shovels. Early & late.
Old Jul 4, 2018 | 08:25 AM
Peterbuchberg
6th Gear
yes I do. The breather valve was wrong for the model year.
Old Jul 5, 2018 | 07:10 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The use of gauge pins will help determine the gear pitch diameter, and the exact gear you'll need, if in fact that is the issue.
Old Jul 5, 2018 | 08:15 AM
Peterbuchberg
6th Gear
I know but I thought that a smaller size pinion gear would change the sound, cause it was smaller. Just a little difference in sound, but no.
Old Sep 27, 2018 | 06:31 AM
pjb's Avatar
pjb
My 76 FLH sounds the same. I've been trying to locate the noise for years. No luck.
I've changed cam gears also, no change.
I removed the belt in the primary, and went back to chain, no change.
Replaced clutch hub and bearings, no change.
Replaced primary case bearing, no change.
Replaced cam bearing, no change.
I have not replaced the cam cover bushing yet.
Old Sep 27, 2018 | 03:09 PM
Peterbuchberg
6th Gear
i just found out that my pinion shaft was bend. Replaced it and I hope its quiet now.
Old Sep 27, 2018 | 04:28 PM
pjb's Avatar
pjb
You're saying it's quiet, or you haven't done it yet??
please report back.
