Compression & Leak-down Results - Easy-Start
Old Sep 2, 2018 | 11:11 PM
Z's Avatar
Z
Default Compression & Leak-down Results - Easy-Start
Ran compression and leak-down tests on my troubled 100" build (rear cylinder 100 degrees hotter than front w/ 100 careful miles toward break-in).
Leak-down was done with engine warm but not operating temp. 7% in rear cylinder, 5% in front. Since I've seen many reports indicating not much difference cold to hot, I suppose I can call this good?
The compression test was complicated by having S & S Easy Start cams. I got the bike to operating temp (250-degrees), killed the engine, popped the connector off the front injector, inserted the compression tester, started the engine and blipped the throttle a couple of times until the needle stopped climbing and got about 135 PSI. Did the same on the rear and got about 150 PSI.
Keep in mind that during these compression tests, I was not able to hold the throttle open as you normally would, so the results will be lower than if performed without Easy Start cams.
So, any thoughts / opinions about these results?
As usual, thanks in advance!
https://youtu.be/RymriI5MYpE
https://youtu.be/0V0cWlt00XU
Old Sep 2, 2018 | 11:59 PM
donk_316's Avatar
donk_316
This should be in your other thread for simplicity sake. No need for a new thread.
Old Sep 3, 2018 | 08:33 AM
Z's Avatar
Z
Yes, it could be placed in my previous thread.
While related to thatt thread, placing it there might cause someone with specific experience in Easy Start compression testing to pass over it.
Also, listing it as a new topic will make it more likely for those searching in the future for topics with "leak-down" or "compression test" in the title to benefit from the replies.
Old Sep 3, 2018 | 10:49 AM
bustert's Avatar
bustert
i say you are good to go. street machine leak down above 92% is good to go although higher is better.
the compression is in the 10% diff'l range so you are good to go.
as far as taking a engine running compression, that is exactly how you do it on a diesel and on older gas machines like coopers and such, set the main gas valves and cyl loading while running.
Old Sep 5, 2018 | 06:21 PM
Z's Avatar
Z
Bustert, I think it looks that wsy too.
Anyone have an idea how much lower the compression would be when done this way rather than with the throttle blades wide open?
Old Sep 8, 2018 | 08:19 AM
bustert's Avatar
bustert
i do not think it to be lower. if you look at it, it would be more averaged out. at crank speeds, rotation would be slower and no back-pressure from downstream. at running rpm, you have downstream pressure effects, compression heating due to higher rpm. i would not expect a large diff'l. if anything probably higher by a tad. another point is that the rings would seal better. running compression on a diesel is higher than cranking.
Old Sep 8, 2018 | 09:43 AM
Z's Avatar
Z
Thanks bustert, for the sound reasoning. Makes sense to me.
Old Sep 8, 2018 | 10:02 AM
TomCop's Avatar
TomCop
Did a test on my setup,not with an easy start cam, but with HD Automatic Compression release enabled and disabled.
With ACR enabled I get around 168 PSI, with ACR disabled it's 230 PSI.
Attached Thumbnails Compression & Leak-down Results - Easy-Start-photo343.jpg   Compression & Leak-down Results - Easy-Start-photo607.jpg
Old Sep 8, 2018 | 10:08 AM
Z's Avatar
Z
Interesting.
Did you do this at cranking speed or with the engine running?
Old Sep 8, 2018 | 10:31 AM
djl's Avatar
djl
OK, how does the actual compare to calculated? 50-60 psi variance is typical.
