Impact on crank?
Old Sep 8, 2018 | 06:20 PM
xcbullet's Avatar
xcbullet
Default Impact on crank?
I think I spun my crank loosing the compensater with impact. It's either that or the new stator rotor is out of balance. I shouldn't of done it but when I seen the manual said to take impact to loosen it. If I did spin crank, I should be able to see on the cam side? I know it was .003 before. Bike has vibration that it didn't have before, sounds different and don't rev like it did. I think I'm about to learn all about the bottom end. Any tips welcome. I'd like do do as much as I can, if not all the work.
Old Sep 9, 2018 | 08:44 AM
prodrag1320's Avatar
prodrag1320
highly doubt you wacked the FW out of true by using a impact,if it was that loose,it would have gone out of true just by riding it,.003 is a lot of run out on a evo.might be time to have it looked at
Old Sep 9, 2018 | 09:57 AM
F150HD's Avatar
F150HD
why did you use an impact? breaker bar takes it off easily if you drop your weight on it. Also using the primary locking bar of course.
Old Sep 9, 2018 | 10:53 AM
xcbullet's Avatar
xcbullet
It's first year of twin cam. Getting ready to pull both side covers off to check run out. I hope your right.
Old Sep 9, 2018 | 12:16 PM
xcbullet's Avatar
xcbullet
I think you are right about the crank. Looks like magnet came off drain plug and was wedged on top of starter ring gear against the starter shaft. PTO side is within .0005inch.
Old Sep 9, 2018 | 12:34 PM
xcbullet's Avatar
xcbullet
Going to close it up. Thanks
Old Sep 9, 2018 | 12:43 PM
Zerk's Avatar
Zerk
Some one forum says all the garages uses impact. Probably they are in hurry to make money. I just took one off last week with breaker bar. I tie down rear brake.
Not saying that is your problem. I replaced a stator last night, since I had primary off.
Old Sep 9, 2018 | 01:36 PM
Mattbastard's Avatar
Mattbastard
I cut a piece of steel bar about 6" long and put it between the sprockets to lock them in place while I hit the nuts with a breaker bar. Same for tightening only torque wrench.
Glad your issue wasn't more involved.
Old Sep 9, 2018 | 03:21 PM
xcbullet's Avatar
xcbullet
I use a plastic block and I just put it Together with it left in there. Joy
Old Sep 10, 2018 | 05:23 AM
F150HD's Avatar
F150HD
plastic step block = bad, many threads discussing it here. Do some reading.
