Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Was able to get it out threw the inspection window. Bike seams back to normal for the most part, maybe some vibration, but might of been that much before. Free reving again.
you're the same guy mixing 10W-40 and ATF and putting it in your primary?
Been using impacts to bust compensators loose oh harleys about 40 years nowand I've yet to tweak a flywheel doing it and we're into triple digits for numbers worked on. On the other hand I've had to fight buggered up parts many times from well meaning knuckle draggers and their breaker bars rounding **** off.
How do you guys think these things are assembled on the line? There isn't some gorilla with a 4 ft breaker and jam bar it's a regulated torque monitoring impact.......
Ya it shifts to smooth maybe I better take it out. O and I mixed synthetic and Dyno. Sorry I'm not as perfect as you, make mistakes but the fluid isn't one of them. I'm still a work in progress.
? was just restating what "you" stated in a different thread. Have read 1000s of tech posts here and elsewhere, was first I heard of someone mixing ATF and motoroil.
Not assembled on the line with an impact. One reason being is that impacts being used to tighten are not accurate because it's pulsing against compensator ramps. Also, Impacts are not recommended due to possibility of damaging charging magnets.
No way is an impact going to twist a '99 to '02 TC crank with the additional support of the Timken 'lefty' bearing. With stator and drive belt replacements over the last 165,000 miles, I've wacked that crank with an impact on my '00 TC at least a half dozen times. It's still a smooth running motor. And yes, shops use impacts on HD cranks.
As said crank is fine. Bike is on the road for a week and running like a champ. Will I use impact in the future to break loose? not sure. Sure glad I didn't have to call darkhorse and tear everthing down. Hoping to get 200,000 miles before I have to worry about that
