103 Build ???
Old Sep 26, 2018 | 08:32 PM
Blue Tick's Avatar
Blue Tick
Default 103 Build ???
I'm looking for ideas/suggestions on proceeding with more on my current build. Bike is a '16 Limited. I've already swapped the cams to S&S 551 gear drives, camplate, oil pump, tappets, quickie pushrods and running a D&D fatcat. My debate is whether I should leave it alone or throw more at it. I've thought about porting the heads, but then think if I'm doing that I might as well add some inches to it, valve job, etc, etc. For my guys that know way more about engines than I do, what would you suggest I do? Money is a consideration, but I want it done right and most important to me is reliability of what is being done.
Thanks in advance.
Old Sep 27, 2018 | 05:49 AM
prodrag1320's Avatar
prodrag1320
doing a 107 or 110 kit & headwork would be about all you can do,if doing the heads,make sure you pick someone who knows how to port for low end TQ & not just hog the ports out for peak CFM.wont work very well with the 551 cams
Old Sep 27, 2018 | 08:02 AM
Blue Tick's Avatar
Blue Tick
Thanks. I want the low end and the wet head leaves limited options for sure on what I can do. I wondered if that 551 was going to kill me since S&S says they don't like anything over 10 and the exhaust side closes earlier than other. I do like the gear drive setup though better than chain.
Old Sep 27, 2018 | 05:43 PM
94 ultra's Avatar
94 ultra
I did the FM 110 kit with LVL B heads and 777 and it runs very strong
monster715
Engine Mechanical Topics
17
Nov 18, 2014 08:46 PM
Pender1
Jul 1, 2014 10:47 PM
icecaps
Exhaust System Topics
Nov 13, 2010 10:07 AM
WARG
18
Feb 25, 2009 07:59 AM
Classic King
Jul 3, 2007 07:41 PM
