Engine build
Old Nov 5, 2018 | 12:06 PM
harleymon55's Avatar
harleymon55
6th Gear
Default Engine build
I own a 2007 Roadglide that had a stock engine but had it built to a 103. If Iwant to go to say a 110 or 117 could I using the same crank and bottom end?
Old Nov 5, 2018 | 12:48 PM
k-weaver's Avatar
k-weaver
You can get 110 slip-ins but thats as far as you can go without ripping apart the bottom end.
Old Nov 5, 2018 | 05:59 PM
martinj's Avatar
martinj
To be clear, going larger than 110" means splitting the cases and having them bored for the larger diameter cylinder spigots. Consider crank work while you have it torn down if you go this route.
Old Nov 6, 2018 | 07:29 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
You can use the OEM crank, but it needs a "tune up".
Have one on the dyno currently.
Scott
Steve Cole
Milwaukee Eight (M8)
121
Sep 18, 2018 12:46 PM
MattDunne
Aug 12, 2018 11:01 PM
natural gasser
Exhaust System Topics
Feb 1, 2011 01:29 PM
davlyo
Nov 1, 2009 12:17 AM
csbreeze
Jan 31, 2008 01:54 PM
