Piston dome
Old Jan 5, 2019 | 02:00 PM
  #31
Max Headflow's Avatar
Max Headflow
Originally Posted by Kingglide549
I think that is exactly what I use.
Is that a piston for a turbo engine there?
40 over 95 ci KB forged with 11cc domes.
Old Jan 6, 2019 | 09:38 AM
  #32
Kingglide549's Avatar
Kingglide549
Must be a shallow chamber?
Just curious.
I like to see what other people are up to
Old Jan 6, 2019 | 09:57 AM
  #33
Max Headflow
Just curious.
Stock 07 heads milled only to clean the gasket surface, 84.5cc CR works out to about 10.8 to 1.
Old Jan 6, 2019 | 10:42 AM
  #34
Kingglide549
Thanx.
Appreciate that .
Old Feb 5, 2019 | 09:15 AM
  #35
harley#1's Avatar
harley#1
piston is a JE 107 10;25;1 part no. 317211 . called and tech says it is a +2cc dome. was told this compression is calculated with stock 85cc heads and .45 HG. any decrease in head volume or HG will increase this compression. does this sound right. thanks.
Old Feb 5, 2019 | 09:55 AM
  #36
Max Headflow
Calculator say 10.49 with those numbers is you set the HG id to 3.955.
http://www.bigboyzcycles.com/TwinCamComp.htm
Old Feb 5, 2019 | 10:10 AM
  #37
djl's Avatar
djl
At 0.000" deck height and I bet Kingglide549 has never even seen a flea fart.
Old Feb 5, 2019 | 11:30 AM
  #38
Kingglide549
Concentrating molecular distortion from the breach at the far end of the azimuth ...of the flea fart,-
It can make as difficult as possible not to send the combustion and the aftermath the wrong direction, then it is a win win.
I have been watching everyone one here as to what they are doing. (outside the stereo and amp BS)
The only conclusive transaction of thoughts is this -without measuring it is all guessing.
The other thing is I have had trouble with online calculators in the past.
I was trying to use Big Boys about two years ago and it kept coming up two full points more then what I was coming up with.
There is a lot, and then a lot more to be said about the correct cam with static high CR ratio / dynamic,
as one does not have much to do with the other, as far as numbers for bragging rites.
Old Feb 5, 2019 | 12:00 PM
  #39
Max Headflow
The output is only as good as the input. I've got a spread sheet that matches the BB calc pretty well. Probably due more to the precision which Pi has been calculated. CCP can be off as it's only an estimation..
Static versus dynamic.. There is a relation.. You are definitely not going to get 10 to 1 dynamic out of a 7 to 1 motor without pressurizing the intake tho. HDs typically don't get more much more than 100% VEs without fancy intakes (like single runner) and exhausts.
Old Feb 6, 2019 | 02:01 AM
  #40
carltonpettiford's Avatar
carltonpettiford
Stage II
There are three types of piston dome. It depends on what is the power of your bike or car. Pistons domes are always connected with the engine with a vehicle.
