Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
So I have a 03 dyna it started to tick from the front top so I checked the lifters they were good. I found the camp late was broken at the crank and the bushing was split. I eneded up buy a fueling cam kit changed it all. Fired it up still ticking. Anyone have any ideas also the front head the exhaust valve is rusty red on the piston side and the Intake is black
Could be rocker shafts rotating back & forth & tapping against the support bolts.... very common.
Have a look around my website, might be just what you need.... thousands and thousands of happy customers world wide
John @ Rockout
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
