Valve train info
Old Feb 6, 2019 | 02:05 AM
cuclainne's Avatar
cuclainne
6th Gear
Default Valve train info
Guys, I have a stock 2007 DYNA FXD BIG TWIN 50K+miles. I want to replace my lifters, rockers, rocker pins and possibly the rocker arm supports. I want to stick with non adjustable push rods. I am look at S&S products, they have a good rep. Thoughts on this, what are good options. Thanks
Old Feb 6, 2019 | 02:19 AM
JayStronghawk's Avatar
JayStronghawk
Find it all Here ..
https://www.fuelmotousa.com/p-33972-...bore-kits.html
Old Feb 6, 2019 | 09:59 AM
djl's Avatar
djl
Understand lifter replacement but why the other components? Unless damaged, all should still be within service limits. Check the rocker shafts for witness marks that would indicate movement in the support and consider installing a set of Rocker Lockers. S&S Standards would be a suitable lifter replacement but if you want to spend a bit more, look at the Premiums.
https://rockerlockers.com/
Old Feb 6, 2019 | 02:37 PM
ROCKOUT Rocker Products
Sponsor
Have a look around my website, cheap & very effective addition while you're in there
John @ Rockout
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Feb 7, 2019 | 05:59 AM
cuclainne's Avatar
cuclainne
6th Gear
Djl, Thank for the quick shout back. Yep, will definitely go after the lifters but figured I would tinker around while I am in there and replace some other parts in the valve train. Have 50K miles, live in Japan and don't want to break down over here because that can be expensive.
Old Feb 7, 2019 | 07:29 AM
hrdtail78's Avatar
hrdtail78
Can't go wrong with S&S on valve train parts. Why do you want to stick with solids? If you can measure what you need. SE makes solids in stock, 3 plus and 3 minus that would be easy for you to source.
Old Feb 7, 2019 | 07:32 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
FWIW, the only major real wear item is the lifters in that list.
We've seen 130,000 plus on those components in service wear limits.
Inner cam bearings would be a mighty good idea.
Scott
RLH3175
EVO
18
May 2, 2017 07:19 PM
LenBoyLo
Sep 16, 2016 10:53 AM
Sportylee
Aug 21, 2016 04:22 PM
cthowards
May 15, 2011 09:12 AM
Red Bull
Jun 4, 2008 10:53 AM
