pushrod gof
Old Feb 7, 2019 | 07:37 PM
dynamac's Avatar
dynamac
Default pushrod gof
I was installing the adjustable push rods back after a cam swap. I got the intake all tightened and adjusted, starting putting in the next one and noticed the o ring was missing. It had been adjusted for ten minutes. So i took it out. Does anyone know if I can reinstall it or do I have to wait since I had already did the turns and it bled down.
Old Feb 7, 2019 | 07:57 PM
hrdtail78's Avatar
hrdtail78
Adjust it again and don't turn the engine over until it spins with you fingers.
Old Feb 7, 2019 | 08:08 PM
RANGER73's Avatar
RANGER73
Just take it out again and start over.
Old Feb 7, 2019 | 08:15 PM
dynamac's Avatar
dynamac
Thank you. Wasn't sure if I had to wait. Now I can finish tonite!
Old Feb 8, 2019 | 09:14 AM
Ed Ramberger's Avatar
Ed Ramberger
If it was adjusted properly, and the lifter bled down, take it out, install the o-ring and install it as if it is a solid pushrod - no adjustment necessary. Because the motor was not started, you will notice it will spin right away because the lifter did not pump up.
gnafin
EVO
Jul 28, 2014 07:18 PM
AllenW
Exhaust System Topics
11
Apr 23, 2013 08:33 AM
cowentz
Mar 9, 2012 08:53 AM
lagunatic
Shovelhead
Aug 4, 2011 08:07 PM
Taterdog
23
Apr 13, 2008 06:47 PM
