Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
IME high or low refers to the return voltage of the circuit
Low = low return voltage, usually indicates higher than normal resistance or open circuit, The return voltage the ECM is reading is lower than expected
High = high return voltage, usually indicates the ECM is not seeing the expected voltage drop for the given sensor load or shorted to ground, the return voltage the ECM is reading is higher than expected
