Adjustable vs solid pushrods
Old Apr 11, 2019 | 05:01 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Using adjustable pushrods to work around removing rocker box covers has never been a good idea to me.
You are getting into the cam chest, why not have an nice fresh set of rockerbox gaskets installed also?
I do not subscribe to the idea that using adjustables allows you to set a different pre load, you may change the running position of the piston inside the lifter, but the load on the pushrod does not change, the lifter has the same amount of pressure on the piston no matter where its running position is, be it high or low inside the lifter.
I agree with Madnss that using an adjustable pushrod in conjunction with a self adjusting hydraulic lifter is silly (don`t let the guys who sell these things see this..).
OP, don`t get all puffed up when you see an answer you don`t like. You aren`t the only one we are posting our answers for.
It`s a public forum.
Old Apr 12, 2019 | 06:06 PM
jjscott's Avatar
jjscott
Thanks for the info and advice. It wasn't my intent to ruffle anyone's feathers, but after re-reading my initial response, I can see how it could be interpreted that way. Apologies for that and thanks for all of the responses! Much appreciated.
Ron C
Engine Mechanical Topics
Jul 9, 2014 12:13 PM
Born2cure
May 30, 2012 12:35 AM
SURFOR Chop
Exhaust System Topics
11
Mar 26, 2011 08:51 AM
okiedokie
Shovelhead
Nov 9, 2008 03:29 PM
