Adjustable vs solid pushrods
Putting the labor time benefit aside, what are the pro's & cons of using an adjustable vs. solid pushrod? Is one always better or worse than the other?
Any downside to using them? Can they work their way out of adjustment overtime?
I myself prefer perfect fit push rods, but I do realize Im the minority for preferring this.
Why, because of the cost of the tubes and rods. Small chance of them coming Loose and its just more o-rings to possibly leak.
I leave adjustables for when I run hydrosolids or solids.
I think its silly to purchase adjustables for the sole reason of adjusting them for a stock type hydraulic lifter. Just my 2 cents.
my last statement was not directed at you at all. I was rambling about pushrods and my 2 cents about YOUR QUESTION. Little sensitive today? Lol
The OP may be able to run the OEM pushrods; depends on cam base circle and head gasket. A .030" head gasket will add .015" to the OEM pushrod preload which may be enough to keep the valve train quiet if the added preload is not offset by a reduction in the cam base circle. So, why not give the OEM parts a try and if the valve train is noisy, they can be replace with adjustables. If the OP is not a DIY guy (seems not to be) and this is the only modification being considered, OEM or perfect fit pushrods make sense.
There is a downside to adjustables. The fact that one has to adjust them is one and the possibility of an adjuster backing off is another. I know from personal experience that adjusters can back off. While it is uncommon, it can and does happen. Having said that, even though I have had an adjuster come loose twice, I run adjustables in the performance built motors in both my bikes. However, I do use, very sparingly, a tiny bit of red Loctite between face of the adjuster and pushrod bottom. If I did not suffer from tinkeritus, I would have installed perfect fit pushrods but last season, I ran three different cam sets so adjustables made sense. In addition, since the dealer is doing the work, if an adjuster does come loose and results in damage, the repair should be on the dealer. There is the inconvenience of a roadside breakdown and subsequent tow is not a warranty item.
I know, the OP asked "what time is it" and I replied by telling him how to build a watch; sorry.
