Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Good morning , I just picked up an old chopper with a weird motor on it. I'm looking to see if anyone has any info on it. It has a shovel bottom, and an evo top ,but has four spark plugs. Teo on each side. The heads look like a factory casing not homemade. The old owner said it's a shovelution. Where can I learn more about it and also find a casting number on it? Thanks
It wouldn't be impossible to put an Evo top end on a Shovel bottom since they use the same base cylinder hole pattern and single cam valvetrain geometery. Combine that with a crafty machinist who's capable of adding a spark plug to the cylinder head (also not too difficult) and Bob's your Uncle.
We ran STD 5 bolt oval port heads on our 108" Shovel cyls/lower end AHDRA racer.
Changed cam/lifter blocks/lifters/exhaust...........picked up 30 hp over what we had.
Not made in China.
Scott
