How to Increase Compression Ratio on a M8
Old Sep 3, 2019 | 02:34 PM
  #31
djl's Avatar
djl
Originally Posted by Jtaylor73700
What are the stock measurements for these above calculations
What rigidthumper is tellling you is that "stock" chamber volume and deck height vary from motor to motor; the only way to know for sure is to measure. CC the heads and measure deck height. Most using one of the online calculators will use .007" as deck height and 86cc as chamber volume. I did some Googling and learned that CP/Carillo uses 86.5cc as M8 chamber volume for manufacturing purposes. I have no idea what the M8 piston dome volume is considering there are four valve reliefs. However, as rigidthumper also points out, guessing is guessing and no substitute for accurate measurements.
trackadaptor
Jul 24, 2020 02:47 PM
gaslog4
Aug 29, 2015 06:06 PM
txphatboy
Engine Mechanical Topics
51
Apr 5, 2015 12:46 PM
san1sjd
Shovelhead
Aug 30, 2012 06:09 AM
skruzluce
Exhaust System Topics
Nov 8, 2009 04:31 PM
