Surging idle on startup
Old Sep 6, 2019 | 05:52 PM
Woodcm96's Avatar
Woodcm96
Stage II
Default Surging idle on startup
I have a 2008 FLHX that when cold started it idles from 875-1300, have change engine temp and map sensor out, all stock except foe stage 1 and fp3 tuner, idle straightens out when it reaches operating temp.
Old Sep 7, 2019 | 06:46 AM
nutsandbolts5212's Avatar
nutsandbolts5212
Did you check for codes first?
Ride Safe!
Old Sep 7, 2019 | 06:48 AM
Kawickrice's Avatar
Kawickrice
Sounds like the idle map is off. Remap it that should calm down the idle.
Old Sep 7, 2019 | 07:44 AM
Woodcm96's Avatar
Woodcm96
Stage II
It threw a code saying ecm not getting enough voltage check for air leaks and throttle plate sticking no leaks and throttle plate not sticking. And ive remapped it many times its still the same.
fourburgs
Milwaukee Eight (M8)
Jun 29, 2017 05:04 PM
peci02@bellsouth.net
Apr 19, 2017 05:28 PM
NWGlide
2014-2024 Touring Models
Apr 9, 2015 09:25 AM
VBdiver
Oct 12, 2012 12:20 PM
rbabos
Sep 7, 2008 11:05 AM
