Andrews 37H not enough anymore
Old Oct 7, 2019 | 08:56 AM
Jay Guild's Avatar
Jay Guild
Default Andrews 37H not enough anymore
My current build is an 06 Dyna with big bore 97" cylinders, 3cc domed pistons, SE high flow intake, Fat Cat 2 into 1 exhaust, Andrews 37H cams, S&S Premium lifters and adjustable pushrods, the Fuel Moto Level B CNC ported heads , and an HPI 51mm throttle body with 4.9 gps injectors . I have upgraded the clutch with a heavy duty spring, a Baker Kevlar extra plate clutch pack, and an AIM VP84 clutch plate. Final drive changed to 30/70. Static compression at 9.98:1. The Andrews 37H has performed well but I recently added the new throttle body, injectors, and the ported heads and feel I should be able to get more out of the build especially considering I have plenty of lift I'm not taking advantage of with the 06 heads. I cruise quite a bit but am very throttle happy on acceleration. I am looking at the Woods-777 but am open to any suggestions from people who cruise but still suffer from happy wrist. I had thought about going to the Andrews 57 just to get the lift, but looking at dyno charts they don't seem to perform as well in Stage 4 builds.
Old Oct 7, 2019 | 10:20 AM
Max Headflow's Avatar
Max Headflow
The 777 is a good cam but it needs more compression. Tman 590, the newer one with the CR set to 10.8 would be a lot more fun. I ran an 02 RK with 95 ci at 10.8 and a Crane H290 for about 45000 miles. Bike pulled strong. The H290 was hard on lifters tho. Ended up replacing them about every 10K. I ended up going to a Andrews 55. Lost a little low end but did pick up some HP up top. I went to a set of 0.040 KB pistons when I rebuilt the top end which helped on the low end and seemed to give a little boost. The newer Tman590 is really close to H290 specs.
Old Oct 7, 2019 | 11:09 AM
Jay Guild's Avatar
Jay Guild
TMan 590 looks interesting. Also considering the Andrews 67 and the S&S 585.
Old Oct 7, 2019 | 11:46 AM
rhuff's Avatar
rhuff
Completely different bikes as my 107" all bore was on a 2003 RKC. I had R&R stage 4 heads and first cam was Andrews 67. The static on that bike was 10.83 and the 67 was a dog until 3200 RPM. Might be much better on a light bike. IMO, that cam needs even more compression that 10.8. Of course, it screams to the redline once it hits. I replaced it with old TMAN 590 and night and day better. Hit at about 2200RPM and ran out 99 percent as hard to the redline.
Does your builder happen to be in Des Moines area?
Old Oct 7, 2019 | 11:58 AM
Jay Guild's Avatar
Jay Guild
Good to know. Thanks for the input. My builder is in the Des Moines area. I use the Hyperformance shop out of Pleasant Hill with master builder Randy Torgeson.
Old Oct 7, 2019 | 01:08 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Ask Randy, he would know best.
Scott
Old Oct 7, 2019 | 02:09 PM
Tat2u's Avatar
Tat2u
The S&S 585 is an awesome cam if compression is set in the mid to high 10's
Old Oct 8, 2019 | 12:24 AM
rhuff's Avatar
rhuff
He loves that 67 cam. You shouldn't. Ask me how I know.....
Old Oct 8, 2019 | 09:46 AM
Jay Guild's Avatar
Jay Guild
Yeah, he likes the Andrews cams. He suggested the 37 and 57 when I did my initial build.
Old Oct 8, 2019 | 11:46 AM
rhuff's Avatar
rhuff
I love andrews cams too, but the 57 is overshadowed by similar cams. The 57 reminds me of a camry. The 67 reminds me of a ferrari- tough to harness and use all that's there without a ton of compression. There are much better cams than the 67 for most applications. Again, you have a light bike so it's not a bad cam, just make sure your compression is high enough (10.8 IMO at a minimum).
