Lifter size and id
Old Jan 25, 2020 | 06:43 AM
98hotrodfatboy's Avatar
98hotrodfatboy
The body.. The service wear limit is .003" for lifter fit to the bore of the lifter block.. As far as I know the lifter diameter is .842".
Old Jan 25, 2020 | 12:22 PM
marcodarq's Avatar
marcodarq
91-99 were the same, larger diameter .903. in 2000 they went to the .842......
Old Jan 25, 2020 | 02:22 PM
Larry Baucum's Avatar
Larry Baucum
Default Lifters
There’s two size lifters.92and .842
Old Jan 25, 2020 | 03:48 PM
marcodarq's Avatar
marcodarq
91-99 are the .903, 2000 and later are the smaller .842. all the lifters in one engine are the same size not a mix of the 2. if your engine cases are 91-99 you use the larger diameter .903....if your engine cases are 2000 and later ( i dont know what year this stops at) the lifers are the .842. hope that clears that up.
early (first and second gen) twin cam lifters are of the .842 variety.
m
Old Jan 25, 2020 | 05:48 PM
98hotrodfatboy
I should of said for the big wheel.. never messed with the latter..
Queen-of-Clubs
May 16, 2016 07:26 AM
big kal
Jul 3, 2011 05:30 PM
biker01
May 1, 2008 08:23 AM
schumacher
Feb 13, 2008 05:46 PM
harleymania
Feb 2, 2008 04:27 AM
