Help with weird code display
Old Feb 3, 2020 | 07:18 AM
ricks2524's Avatar
ricks2524
Default Help with weird code display
My 06 deluxe threw an check engine light yesterday. When doing a code check it shows P1353 and P 1356. These are Front and rear cylinder "no Combustion" What gives the bike is running fine. This also happened a few weeks ago then went away.. I also need to add that it listed a part# 34317-06. There is not parts listed at Harley for this number, Any clues?
Old Feb 3, 2020 | 07:26 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
This might help. IDK
https://www.hdforums.com/forum/dyna-...353-p1356.html
Old Feb 3, 2020 | 08:00 AM
ghost183's Avatar
ghost183
Originally Posted by Andy from Sandy
yah, i was going to suggest that BS plastic line in the tank from the pump to the QD
dont worry about the 34317-06, its the part number for the display that provided you the engine codes.. lol..
Old Feb 3, 2020 | 04:45 PM
Ed Ramberger's Avatar
Ed Ramberger
FYI - that vintage had no combustion codes in completely stock trim and the cals were revised. There may be a revised stock cal for your bike. It can also happen if the mufflers were changed or someone used aftermarket plugs or wires. Bottom line is it can be real or a code generated by parameters that were too "tight" in the OE cal.
masterblaster
Mar 19, 2011 04:06 PM
ruin66
Jul 10, 2010 08:36 PM
cardoc001
Mar 21, 2010 05:59 AM
chase7317
Aug 18, 2008 09:04 PM
blackfinbob
Jan 8, 2007 10:56 PM
