110 head torquing issue
Old Feb 23, 2020 | 06:33 PM
RollieB's Avatar
RollieB
Default 110 head torquing issue
Rebuilding an 07 cvo RK and I'm at installing heads with Cometic gaskets. Been through the sequences and I'm at the 42 ftlb final round. After completing that I'm going around in sequence and checking them till nothing moves. All good but right hand side on the rear head. Torque rear one then front on and they both move. Back to rear and it moves and then the front again,some thing. What gives?
Old Feb 23, 2020 | 09:07 PM
ghost183's Avatar
ghost183
1) did you check the studs were tight before reassembly? maybe youre tightening the studs along with the head bolts..
2) is the gasket in correctly? maybe youre crushing the brass rivet??
3) is the head sitting correctly?
4) did you use antisieze? that will change the torque value alot
thread locker does too but almost nothing
FYI, i found the best way to seat an MLS is to let it sit for 10-15 mins between the final 2 stages of torqueing.. i came across this by accident letting the bike sit over night disassembled, i double checked torque next day before reassembly and they lost an average 2 lbs, some none, some 3, one lost 4lbs
Old Feb 24, 2020 | 06:48 AM
RollieB's Avatar
RollieB
Everything checks out. In place proper,tight,rivets have clearance. Followed manual and used oil on underside of bolt flange and on threads. On further inspection,the one bolt isn't actually torquing more each time,it's flexing. I think I've got a bolt that isn't seating on the head properly. Guess the head is coming back off.
Old Feb 24, 2020 | 10:55 AM
60Gunner's Avatar
60Gunner
Light coat of oil. Very light. Too much oil on the threads will give ya a wet torque.
Also, using mls gaskets you don't use orings. You didn't by chance leave one stuck in the head?
Just throwing that out there.
Old Feb 24, 2020 | 01:12 PM
RollieB's Avatar
RollieB
I don't think I used to much oil but I'm gonna clean everything up and give it another try this evening.it seems like the front bolt is bottoming out before it fully seats on the head,but the stud doesn't seem to be sticking up any higher than the rest. Can a guy clean up the threads on the bolt with a tap?maybe there's some gunk up in there?
Old Feb 24, 2020 | 05:59 PM
60Gunner's Avatar
60Gunner
Chase them yes. Cut them no.
Old Feb 25, 2020 | 02:23 PM
ghost183's Avatar
ghost183
use a wire brush to clean them, dont chase them, you might cut into the walls of the thread and weaken the thread, the OEM threadlocker, dirt, etc etc might provide enough resisitance to push the thread cutter into the threads them selves and cut into them
captchaz
Shovelhead
17
Oct 17, 2018 10:09 AM
donk_316
Sep 28, 2018 08:55 AM
BigRed72
Shovelhead
15
Dec 6, 2014 02:55 PM
ron1953
Shovelhead
Apr 15, 2008 10:57 PM
hubbard_88
Nov 11, 2007 04:24 PM
