Rounded manifold bolts -help
Old Mar 8, 2020 | 01:50 PM
SC07Bobber's Avatar
SC07Bobber
Default Rounded manifold bolts -help
07 FXDB
The 2 tough ones are now rounded. These are the 2 bolts at the primary side of the manifold. This is not my first time taking the throttle body/manifold off.
So the two on the throttle body side I got loose no problem. But the two on the primary side are impossible this time around.
I used my special 1/4” angled ball Allen wrench, but it’s just mangling that soft bolt.
So, considering the tight space I’m working in, what are my options?
How can I get these out?
Thanks.
Old Mar 8, 2020 | 05:21 PM
Gearhead88's Avatar
Gearhead88
Take a 1/4" allen wrench and , using a zip wheel in a die grinder , cut a piece of the allen wrench off. Take the "bit" you just created and put it in the bolt you want out , get it in there as best as you can. Use a long 1/4" box wrench to loosen the bolt . I've taken off several hundred manifolds / throttle bodies , sometimes you are better off to just start out like this and not wreck any bolts.
Old Mar 8, 2020 | 05:51 PM
SC07Bobber's Avatar
SC07Bobber
The 1/4” Allen socket cap head is already rounded. So, it doesn’t seem that this will work. Although it is a good idea to get these bolts out (before they are rounded).
If there was any room, I wish I can hammer in a torx bit, but there’s no way I can hammer it in based on angle.
Old Mar 8, 2020 | 07:41 PM
ntraindavefl's Avatar
ntraindavefl
First w heat gun heat up the bolt area. And have ready a mix gritty cement mix or any compound you can add some coarse mix to it. With finger fill in the stripped Allen head let it sit for handful of minutes then work in the Allen bit. Keep pressure on the Allen wrench and try getting it to turn.
Old Mar 9, 2020 | 05:53 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Mapp gas torch and heat them.
Needle-nose vise grips, and/or a small punch to try to start them to turn.
Hopefully that helps.
Scott
Old Mar 9, 2020 | 07:05 AM
Gearhead88's Avatar
Gearhead88
If the heads are coming off , take them off as a pair , the throttle body can be removed easily by twisting and pulling on it . The screws can be removed once you have better access to them.
Old Mar 9, 2020 | 07:19 AM
touchdown's Avatar
touchdown
I have used needle nose vice grips before. But someone said cut a Allen wench and glue it in place Something like JB weld
Old Mar 9, 2020 | 08:08 PM
Mattbastard's Avatar
Mattbastard
There's enough room to get a good set of beefy vice grips on the head, just crank it down as hard as you can and give it a turn. You only need to break it loose, then the allen can finish the job.
Also, those ball head allens are NOT meant for high torque applications, especially at that size. Get yourself a sacrificial 1/4" allen wrench and cut/bend it to work with those back bolts. Or change them out to a hex bolt you can put a box end wrench onto.
Old Mar 10, 2020 | 07:53 AM
dracer's Avatar
dracer
Or change them out to a hex bolt you can put a box end wrench onto. i always change the allen heads to hex heads when i do work on the manifold.
Old Mar 10, 2020 | 08:14 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I have taken an Allen wrench and taken a little bit off the end of it to make it easier to get into the bolt. If you rounded it with a ball end Allen wrench you'll still have some meat down at the very bottom of the cap screw where you can put an Allen wrench in there. Seat it down with a hammer like I stated a cut off Allen wrench just to break it free It works..
