Rounded manifold bolts -help
Old Mar 11, 2020 | 03:39 PM
07SCbobber's Avatar
07SCbobber
Problem solved.
Thanks to everyone who provided advice.
It was only the the tip or the very initial entrance to the cap socket bolt that was rounded. So, I was finally able to break it loose with a fresh sharp Allen wrench after tapping it in with a small hammer.
Ill be using 12 pt bolts in the future.
Thanks again.
Old Mar 11, 2020 | 03:48 PM
im's Avatar
im
The allen wrench provided and used with a garbage disposal for when it gets stuck has a nice angle that sometimes helps.
Old Mar 11, 2020 | 04:16 PM
Max Headflow's Avatar
Max Headflow
Why use 12 point bolts? You can't slip an open wrench on them from the side. I use ARP flanged hex bolts (same as the 12 but only 6 sided). Head is 3/8" not 7/16 like std 1/4 inch bolts.
thewoozel666
EVO
18
Mar 10, 2020 08:08 AM
ro9beam2002
Jul 10, 2017 12:04 PM
trophy113
Apr 26, 2011 11:16 PM
gli.der
Dec 7, 2008 01:19 AM
moys07dyna
Feb 14, 2008 08:14 PM
