Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I'm trying to figure out the correct part number for Cometic MLS head gaskets. It's for a stock twin cam 96 cubic inch engine.
Stock HD part number is: 16775-99B.
The confusion stems from a possible misprint in a Cometic catalog. I'm seeing (2) different part numbers for the corresponding OEM # (16775-99B)
I'm seeing:
C9790 Head Gasket .030" Spring Steel All Models Std Bore 1999 -UP
C9745 Head Gasket .040" Spring Steel All Models Std Bore 1999 -UP
What is the stock head gasket thickness on a 96ci TC engine?
Look at the attached document and search on "16775-99", and you will see the two different Cometic part numbers for the reference OEM part number.
