So stock gasket is .060" not .045" like I was told. So should I go with the .045" that comes in the kit or the .030" that I WAS considering ? Or buy .060" separately.?????
If the piston is even or below the top of cylinder (deck) use a .030 gasket. Ideally you want to have .030 squish, so choose your head gasket accordingly.
Are you sure about that???
I'd always heard 45thou myself...
Old gasket had a 60 stamped on it and part number, I measure it and over .050".
Googled Oem# and there it was (16773-85)=.060"
Curious because kits offer 30 & 45 so was surprised to see the 60 thousand.
What was your reason for considering the .030 over the .045? I understand it would change the compression but how much? Would it really make a noticeable difference? In the process of a rebuild and curious.
Not sure how much you would notice but given the choice to increase compression slightly to compliment the cam upgrade and might as well do it while I'm there,. Just not sure if I want to go from a 60 to a 30 or 60 to a 45. The .060" gasket thru me off a bit.
For point of reference, because I have all the info to tell me this on my car, in my Vette going from a stock .057 gasket to .030 (with a 4" bore) raises compression from 10.9 to 11.4.
I found it to be a very worthwhile gain. That said, note that I am able to adjust timing very granularly for RPM and load in my car which you can't do on an Evo...and I have knock sensors to keep me safe if I get too aggressive...so not sure you'll be able to take full advantage. Even so, I'd do it. Compression tends to be your friend in a build allowing you to tame a bigger cam which I know you're wanting to do. Heck, as big a cam as you want to run you might want to mill the heads...though I don't know on an Evo where you have to start to worry about piston to valve issues, normally an advanced intake lobe with long duration will cause problems in PtV clearance.
Only potential downside is I think it'd be wise to run adjustable pushrods if you're going to use thinner gaskets, you might be causing too much preload in the lifters if you use stock pushrods.
